1941 Chrysler New Yorker Hot Rod - Page 18 - Hot Rod Forum : Hotrodders Bulletin Board
Hot Rod Forum : Hotrodders Bulletin Board > General Discussion> Projects/Builds/My Ride
  #256 (permalink)
Old 03-07-2020, 04:41 AM
123pugsy's Avatar
Rod...from a Chrysler?
Last wiki edit: Metal shaping
Last journal entry: SEAM SEALER
Wiki Edits: 29
A/C brackets bolt to cubby on passenger side.
ID:	452393   Click image for larger version
ID:	452395   Click image for larger version
ID:	452397   Click image for larger version
The Following 3 Users Say Thank You to 123pugsy For This Useful Post:
idrivejunk (03-07-2020), John long (03-29-2020), Rip VW (03-07-2020)
  #257 (permalink)
Old 03-07-2020, 04:48 AM
123pugsy's Avatar
Wiki Edits: 29
Drain trough in case I spring a leak. Don't want any fluids running out the front and down the firewall.
ID:	452401   Click image for larger version
ID:	452403   Click image for larger version
The Following User Says Thank You to 123pugsy For This Useful Post:
  #258 (permalink)
Old 03-07-2020, 04:52 AM
123pugsy's Avatar
Wiki Edits: 29
I turned down an adapter for the booster/bellcrank connection. Added a hole for a cotter pin. There are four connections on the Kugel unit that came with vinyl lock nuts which will get the same treatment. I don't trust lock nuts after seeing several fall off.
ID:	452407   Click image for larger version
The Following 2 Users Say Thank You to 123pugsy For This Useful Post:
Bob37pont (03-07-2020), Rip VW (03-07-2020)
  #259 (permalink)
Old 03-07-2020, 04:56 AM
123pugsy's Avatar
Wiki Edits: 29
AC and heater hoses ready to go and holes punched in cowl side for bulkhead fittings. Hoses/tubes will run under passenger fender.
ID:	452411   Click image for larger version
ID:	452413   Click image for larger version
ID:	452415   Click image for larger version
Bob37pont (03-07-2020), idrivejunk (03-07-2020), Rip VW (03-07-2020)
  #260 (permalink)
Old 03-07-2020, 06:18 AM
Molon Labe's Avatar
Last journal entry: Floors
Agree on the Ni-cop lines. So easy to work with.
The Following User Says Thank You to Molon Labe For This Useful Post:
123pugsy (03-07-2020)
  #261 (permalink)
Old 03-07-2020, 10:01 AM
Rip VW's Avatar
I will endevour to persevere
Last journal entry: This thread is officially Kaput as of 11/07/2017
Amazing stuff there Pugsy.
The Following User Says Thank You to Rip VW For This Useful Post:
  #262 (permalink)
Old 03-07-2020, 10:03 AM
Too Many Projects's Avatar
Collector of "someday" cars
Last journal entry: continued
Looks great. Just remember, your leak test is not nearly the 900-3,000# force exerted on those lines in use... be careful with the first test drives.
I've had some luck making tight bends with fine play sand in the tube to prevent kinking/collapsing.
The Following User Says Thank You to Too Many Projects For This Useful Post:
  #263 (permalink)
Old 03-07-2020, 10:51 AM
123pugsy's Avatar
Wiki Edits: 29
Thanks.
Not worried. Welding is good stuff. I did a line on CURSE without the bonus sleeve. It had a small drip. I found a pin hole because of my poor vision, added a drop of weld and she's good now.
Too Many Projects (03-07-2020)
  #264 (permalink)
Old 03-27-2020, 06:49 PM
123pugsy's Avatar
Wiki Edits: 29
I took the firewall to work to spot weld the reinforcing channels/angles in place.
I used some aluminum scraps from work for temples for the lines chase.
ID:	453057   Click image for larger version
ID:	453059   Click image for larger version
ID:	453061   Click image for larger version
ID:	453063   Click image for larger version
Gearhead Poppa (03-28-2020), idrivejunk (03-27-2020), Rip VW (03-28-2020)
  #265 (permalink)
Old 03-27-2020, 06:52 PM
123pugsy's Avatar
Wiki Edits: 29
I trimmed the firewall panel and cowl.
ID:	453069   Click image for larger version
ID:	453071   Click image for larger version
ID:	453073   Click image for larger version
ID:	453075   Click image for larger version
The Following 4 Users Say Thank You to 123pugsy For This Useful Post:
Gearhead Poppa (03-28-2020), idrivejunk (03-27-2020), John long (03-29-2020), Rip VW (03-28-2020)
  #266 (permalink)
Old 03-29-2020, 08:03 AM
123pugsy's Avatar
Wiki Edits: 29
I brought the firewall and cubby to work and had the young lad run tack welds around the full perimeter and the plug weld holes. I shouldn't have even punched the holes as it needed full perimeter welding in case of fluid leaks. That was the point of all this extra work from the git go.
The second pic has a sneak preview of a bearing mount location for the throttle cable.
ID:	453153   Click image for larger version
ID:	453155   Click image for larger version
ID:	453157   Click image for larger version
Gearhead Poppa (03-29-2020), idrivejunk (03-29-2020)
  #267 (permalink)
Old 03-29-2020, 08:10 AM
123pugsy's Avatar
Wiki Edits: 29
Everything leveled off and ready to weld..........
ID:	453161   Click image for larger version
ID:	453163   Click image for larger version
ID:	453165   Click image for larger version
ID:	453167   Click image for larger version
ID:	453171   Click image for larger version
Gearhead Poppa (03-29-2020), idrivejunk (03-29-2020), John long (03-29-2020)
  #268 (permalink)
Old 03-29-2020, 08:16 AM
123pugsy's Avatar
Wiki Edits: 29
A bit of clean up...........
ID:	453175   Click image for larger version
ID:	453177   Click image for larger version
ID:	453179   Click image for larger version
ID:	453181   Click image for larger version
  #269 (permalink)
Old 03-29-2020, 08:23 AM
123pugsy's Avatar
Wiki Edits: 29
Roto time is always fun. Although carrying all the bits from the shed and assembling this thing, not so much.
Had to make new arm adapters for the front as it was hooked to my temporary firewall last time I used it.
This allowed bottom access to finish the welding and clean up.
ID:	453185   Click image for larger version
ID:	453187   Click image for larger version
ID:	453189   Click image for larger version
ID:	453191   Click image for larger version
ID:	453195   Click image for larger version
  #270 (permalink)
Old 03-29-2020, 08:32 AM
123pugsy's Avatar
Wiki Edits: 29
The factory had four mounts close to the front of the body, so I figured I should do the same since the fenders bolt on there.
I started with some 18 ga brake formed channels. I zip cut them to size, drilled drain and mount holes. I used some large rings of tubes as anti crush sleeves.
The mount bolt goes thru a 1/4" thick stainless disc that is welded into a round tube, welded to the floor.
ID:	453199   Click image for larger version
ID:	453201   Click image for larger version
ID:	453203   Click image for larger version
ID:	453205   Click image for larger version
