1941 ford 2 dr sedan - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-17-2016, 05:20 PM
i have a 41 ford which i want to do some supension work on. i have a chance to buy a 10941 mercury bare frame. need to know it they are interchangeable or if different what is the difference.
Old 12-17-2016, 05:53 PM
techinspector1's Avatar
Last wiki edit: DynoSim combinations
Wiki Edits: 326
The Ford is 114" wheelbase with 56 1/2" track.
The Mercury is 118" wheelbase with 56 1/2" track.
Old 12-17-2016, 06:05 PM
1941 ford frame
ok there is 4 in diff in wheel base. is that difference in the front of frame due to longer front end on mercury? will my ford body bolt to the merc frame and i modify front of frame by 4 in when changing suspension?
Old 12-17-2016, 08:18 PM
BOBCRMAN@aol.com's Avatar
The wheelbase difference is from the front crossmember being moved ahead in the frame rails and a spacer added to the trans crossmember. Basic frame rails are the same as the Ford of the same years. 41-48.
The last time I used a Merc frame. It was to replace a rusted and damaged 42 blackout coupe that I restored. The 42 Ford crossmember fit the Merc frame using the Ford holes, already in the frame and the trans crossmember was the same, less spacer. Some body mounts were a bit different but the Ford was a short door coupe and the Merc was a 4-door. I just used the coupe body mounts on the sedan frame. The Merc drivers door fit the Ford with minor work on the top rear corner.
I have built a few of these old Fords.. They used to be cheap cores, as few people wanted the "Big" Fords built after 1940. I fell in love with them as a kid in the fifties/sixties. First was a 47 Merc coupe. Powered it with a nailhead Buick.. Tranny and rear axle killer!
Old 12-17-2016, 08:50 PM
bob, this frame is from a merc 2 dr sedan and since i have a ford 2 dr sedan i was wanting to do a heit front end,set v8 and trany, all new brake and gas lines etc. and move my body over. my frame has be hacked on .
i can buy this frame for $250.00 which is reasonable.
thanks for info and any other advice you have.
How wide is the front end on a 1941 Ford Coupe or sedan? TxKahuna Hotrodding Basics 2 05-21-2013 11:08 AM
My 1941 Buick super 8 sedan Buick41 Introduce Yourself 1 05-22-2011 11:20 AM
1941 Ford 2dr. Sedan/1984 GMC Short Bed nhcamper Introduce Yourself 3 12-18-2010 08:38 PM
1941 plymouth sedan deluxe htaplymouth Suspension - Brakes - Steering 3 10-31-2008 12:26 PM
1941 Chevy Sedan Delivery DrJoe Introduce Yourself 3 03-06-2008 10:00 AM
