1947 Chevy Door removal - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-04-2016, 08:12 AM
The screws holding my front door on were so badly rusted I had to drill the heads off. My question is the plate behind the door pillar that the hinge screws go into does it slide out so I can replace?
Old 07-04-2016, 08:19 AM
It's a shame you didn't use the old trick of heating and cooling the bolt.
Removing rusted bolt basics
One of the first jobs I ever had was at a shop doing full on restorations on vintage Fords (we specialized in model 40s 1933-34). By boss taught me MANY things I use every day. One of them was the best trick for getting rusted bolts out that I have ever tried.
You need your torch with a small tip.
Take the torch and make a perfect flame like you are going to weld. Heat the bolt head up till it starts to turn red. (If the bolt is already broken off you will need to saw a grove to use a flat blade screwdriver or have enough to grab with locking pliers) Then quickly cool it with a squirt bottle of water. Repeat, heat it, then cool it. Do this a number of times and the bolt WILL turn right out. If you can, heat the nut around the bolt right before you try turning it out, BUT DON'T HEAT THE BOLT. This will expand the nut from around the bolt. I have did this on Model A door hinges, if you are not familiar with them, it is a 5/16 bolt with a little flat blade screw driver head! A ridiculous design that rusted in to tight to remove around 1950! You can imagine how hard they are to remove in 2000. I have did these with total success, only needing a regular hand screw driver about 99% of the time.
The way I figure the heating and cooling expands and contracts the screw breaking it loose from the rusts grip.
Now, that plate, I believe it's a "cage nut" which means it's caged in there and you will have to drill out some spot welds to remove it. It may even be between two panels and you would have to take the whole pillar apart to remove it.
Let's look at another way to solve this problem. You can carefully grind the broken off bolt down flush with the plate and then drill the bolt out with a smaller drill and re-thread the hole using a tap.
Old 07-04-2016, 09:12 AM
Thanks Brian
I was able to drill out bolts and re-tap holes with no problem
The Following User Says Thank You to Bill Buchner For This Useful Post:
MARTINSR (07-04-2016)
Old 07-05-2016, 04:00 PM
agreed with you
Model A Door Glass Removal golferjc Hotrodding Basics 8 11-13-2015 11:49 PM
chevy c10 door handle interior removal ninmmkmfdm Interior 17 02-12-2013 03:55 AM
1947-54 chevy truck door/cab dent/hinge superdirt General Rodding Tech 4 12-30-2010 10:07 AM
1993 Chevy Silverado door panel removal lelshaddai Interior 2 01-19-2008 07:51 PM
1947 Chevrolet 4 door highroller Engine 3 10-12-2002 07:03 PM
