1947 ford floor board write up - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-24-2017, 07:01 AM
topher5150's Avatar
Last journal entry: random parts offer
I was wondering if any one has a pretty good write up on replacing the floor boards, and rocker boxes for a 1947 Ford passanger car? I have a lot of sheet metal to replace and I want to do as much research as i can.
Old 08-24-2017, 10:25 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
I am not aware of a specific article on your ford. Saying that replacing the floor pan in one of those would not be a whole lot different than in any other car. So just do some searches for floor pan replacement on you tube and google.
Sam
Old 08-24-2017, 01:52 PM
topher5150's Avatar
I was asking specifically for the 42-48 Ford because of all the work needed on the rocker boxes, and rocker panels
Old 08-24-2017, 04:05 PM
If you find a write up on this specific car that is as good as this thread, that would be great. https://www.hotrodders.com/forum/53-b...ir-233635.html
But I doubt you will find anything with as much info. It may not be your specific car but if you just start looking at things and read John's thread on his Chevy you will be able to make the decisions your self now and then when you have question about something.
Study John's thread, you will be better for it.
Old 08-24-2017, 07:12 PM
topher5150's Avatar
looks like some good bathroom reading....thanks
The Following User Says Thank You to topher5150 For This Useful Post:
MARTINSR (08-24-2017)
Old 08-24-2017, 08:39 PM
I have built a 47 Ford convert as well as the 53 Bel Air. Brian is correct that the construction is very similar.
BTW, All 47 Fords used the same floorboard. 4 door, 2 door, coupe, and convertible. All the same!
John
The Following User Says Thank You to John long For This Useful Post:
MARTINSR (08-25-2017)
Old 08-25-2017, 06:56 AM
topher5150's Avatar
I've been keeping an eye out for some floor boards, but they all seem to be on the other side of the country
Old 08-25-2017, 07:15 AM
Check out these folks; they should have everything you need:
1941-48
Old 08-25-2017, 08:52 AM
S10xGN's Avatar
Gotta love a turbo!
This outfit used to be called "B-i-t-c-h-i-n Products", I did my '47 Ford floors and rockers with their sheetmetal. They had really good instructions and you could call at will and ask particular Q's that weren't covered. And don't ask, that car is long gone along with all the paperwork and spares...
Russ
Old 08-26-2017, 04:52 AM
BOBCRMAN@aol.com's Avatar
There is a guy over on the H A M B that did, or is doing, a 41-48 Ford, with pics. Haven't followed the story for a while but he did a bunch of work, as all of these old Fords have the same rust problems. I've done several and still have three bodies out in the barn.
Old 10-26-2017, 10:35 AM
topher5150's Avatar
Just thinking out loud here.....so the aftermarket stuff doesn't come as a whole unit, and buying something cut from the same car will be pretty pricey. I was wondering if any of you guys have ever used floor boards from a newer car?
This weekend I am going to go through the car and take note of what needs to be replaced completely, what is good, and what could be patched. Maybe I won't have to go this route I just like planning ahead.
Old 10-26-2017, 12:13 PM
Wiki Edits: 3
It is possible to use a later floor pan if you find a good one.. Try and find one that has a similar shape to the old one. Of course you will need to deal with body mounts and seat mounts in the new pan..
Sam
Old 10-26-2017, 12:25 PM
topher5150's Avatar
anything from 41-48 works, but I don't hardly see anyone selling floor sections, and if do it's way out west. If that's what your referring to?
Old 10-26-2017, 01:51 PM
Wiki Edits: 3
What I am referring to is going to the local wrecking yard and see if there are any floor pans that may be usable.. There are no rules unless you are going for a 100 point restoration..
Sam
wet floor board gofastz Interior 3 04-06-2014 04:15 PM
Floor board insulation my oldcar Interior 2 10-15-2009 06:39 PM
floor board replacement camaroboy1991 Body - Exterior 3 05-21-2007 03:52 PM
My S-10 Ford 8.8 swap write-up KNanthrup Transmission - Rearend 6 03-18-2005 11:12 PM
No floor board Circus Interior 4 02-07-2004 10:00 AM
