1954 GMC Door adjustment - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-12-2018, 12:30 AM
I am looking for help with how to adjust the doors on my 54 GMC pickup. My problem is the doors shut good at the top but they stick out on the bottoms. I dont see any way to adjust the door bottoms in closer to the cab. Thanks in advance.
Old 07-12-2018, 02:01 AM
Usually the doors are adjusted to line up at the B pillars and then the front fenders are adjusted to correct the gaps at the A pillars. Finally the hood is abjuted last. On some cars the hood must be adjusted to the cowl first and the fenders are fitted to the hood and doors. It is indeed a "dance". On top of that, frequently the upper door (window frame area) gets out of shape or the door gets twisted. A good bodyman can do wonders with a block of wood.
There are always exceptions to every rule. Sometimes bodywork has been done and the door is out of shape, or the body for that matter. Not only were trucks not made to the same standard that cars were, they have been beat up and treated as a tool. Yours for 64 years.
I wish you had titled your thread with the help you needed. MartinSR is a proffesional autobody tech and has owned one of these trucks his whole adult life. He would be the go to guy for your truck. Hopefully Brian will read this and give you more advise than I am able to do.
Good luck and post pictures if you can.
John
Old 07-12-2018, 07:23 AM
I was almost asleep when it occurred to me the truck fenders do not meet the front of the door and have nothing to do with door gaps. The reply above would apply to a car but not the trucks.
Question: Do both doors stick out at the bottom? Many times a rusted body mount or incooerctly shimmed body will cause the body to twist. This will make one boor stick out but cause the other door to sri k out at the top.
John
Old 07-12-2018, 08:29 AM
Are the doors in too much at the A pillar? Because that is the only way it could be out at the bottom rear without the cab being distorted as John mentioned.
Even if the top front is perfect you can move them out a little there to get the bottom to come in making the front "sorta good" instead of perfect to get the rear "sorta good" instead of horrible, get what I mean?
Old 07-12-2018, 12:12 PM
54 chevy truck door adjustment
Thanks everyone for the help. Do any of you know how to shim these doors in or out? My problem is that one door is perfect at the top but sticks out 1/2 inch at the bottom. At one time I had it perfect but then had to remove the door to put new seals on them and now the problem has arisen. I have checked the new seal at the bottom and it fits well so I am left scratching my head. Any ideas?
Old 07-12-2018, 12:33 PM
idrivejunk's Avatar
Grand Prix User
Last journal entry: Last look
I just so happen to have a 54 handy, its our "sign".
Looks like in / out adjustment is where hinge meets pillar, but shims could possibly be stacked between hinge and door shell.
Just providing a visual here really. Hope its the right kinda truck.
ID:	432831   Click image for larger version
ID:	432833   Click image for larger version
Old 07-14-2018, 08:21 AM
put up or shut up
your tilt adjustments should be on the a pillar. Probably lame phillips#3. Get an impact, penetrating oil, and let it sit. Then pull out your door up top which will bring it in at the bottom. Then adjust the fender and it will probably be a pain to readjust as opposed to a 60s and beyond car.
Old 07-14-2018, 06:01 PM
You will find 3 phillips head screws, and two hex head bolts holding the hinge to the pillar.
The phillips heads do nothing much, it's the bolts that you need to loosen to adjust the door in and out.
That said, does the door line up with the hinge pillar? If so, and it's out at the bottom rear, the door may be twisted some. If the door clicks closed with light pressure, perfectly aligned, without the seals installed, then install the seals and it won't close, or is out of alignment, the seals are the problem.
Those doors must be lined up with the pillar, and back of the cab. When you get to that point, then, and only then, can you remove the door from the hinge, leaving the hinge firmly bolted to the pillar. install the new rubbers, then re-install the door. The only adjustment at that point needing anything would be the fore, and aft adjustment on the hinge inside the door.
It's pretty much the same hinge get-up as the cars of that era, only the door lines solely with the cab, and not the fenders.
Another thing I've run into on vehicles of that vintage is the hinge mounts inside the door, or on the pillar, being rusted out just enough (but in places that can't be seen) that I could adjust everything perfectly before paint, and new seals. Then the pressure of the new seals causes failure of the attach points causing mis-alignment. And no way to get it back in line without major surgery.
New AM door rubbers can be a real PITA on an otherwise perfectly fitting door.
Old 07-22-2018, 12:27 AM
bullheimer's Avatar
NEVER use credit cards!
is there no adjustment on the part of the lower hinge that bolts into the cab? been a long time since i've had mine apart and dont know if they are exactly they same as yours but have to ASSume so. any existing shims you can remove? just guessing
Old 07-22-2018, 09:23 AM
There is VERY LITTLE in and out alignment to these hinges. One thing that can help is to add the last bolt down in the hinge that GM added on the later cars and trucks.
The red dot is the hinge pin, moving the location of the pin in or out is way more important than moving the hinge where it bolts to the cab. Now of course you would think moving the hinge where it bolts to the cab would move this pin, but not always, it rocks a bit and you can move the hinge without moving the pin as much.
I put these bolts (the blue dot) in my truck so I can have more control over that pin location. The bummer is you have to have the inner cowl panel out to do it, I welded in a flat stock with a hole threaded for a nut back in there.
It's funny because I noticed this on a 55 Chevy sedan I was working on, they had these bolts back in there where my truck at home didn't, the holes where there but not bolt, interesting.
The Following User Says Thank You to MARTINSR For This Useful Post:
idrivejunk (07-22-2018)
1954 Chevy Pickup Door windows Boulderdesign54Chevy General Rodding Tech 4 05-17-2007 06:35 AM
1954 Chevy Pickup Door windows Boulderdesign54Chevy Introduce Yourself 2 05-09-2007 11:42 AM
1947 to 1954 GMC Body Style Poolpro51 Body - Exterior 11 01-05-2005 09:20 PM
1954 GMC Inline 6 with Saginaw tranny Erik Transmission - Rearend 0 12-01-2003 09:46 PM
1954 GMC V6 3 speed on the floor swap out Flaming54 Engine 3 10-16-2003 05:02 PM
