1954 mercury kustom build questions - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-15-2007, 05:44 PM
62galaxiguy's Avatar
Im buying a 54 merc monterrey 2 dr ht and want to know what late model frames will fit under it? I want to go with modern suspension.Thanks
Old 09-16-2007, 06:53 PM
Youngster's Avatar
1954 mercury custom build questions
The best frame under a '54 Merc is one from a '54 Merc. Unless you've done a conversion like this, you have no idea of the problems you're going to come up against. If the stock frame is solid, rebuild the stock front end and add disc brakes. As for the rear, replace the old springs with a new set. Want more power than the 256motor? Swap in a 302/c6 and an 8" from a mid '70's Maverick. Now enjoy a great little cruiser. Body swaps are very hard to pull off successfully.
Youngster
Old 09-17-2007, 12:28 AM
Last wiki edit: Body and exterior tips
Youngster has given you very good advice. Swapping frames on independent front suspension cars should only be used as a last resort if you can't use an original one.
Best Car Insurance | Auto Protection Today | FREE Trade-In Quote
Old 12-20-2009, 10:47 PM
54merc's Avatar
Stallions Auto Interiors
I left the frame original. All I changed was; I added the spindles and disc brakes from a 1975 Cougar and add the power steering assembly from a 1960 Thunderbird.
this is a saver.... GM build codes TooMany2count General Rodding Tech 24 11-23-2009 09:36 AM
Engine build ideas Rug Engine 23 12-25-2006 01:39 PM
First 4L80E build questions. bugsdad Transmission - Rearend 12 10-22-2004 07:40 PM
New guy here with questions about motor build AustinClassic Engine 3 05-26-2004 03:40 PM
sbc 350 build up questions b/w72 Engine 9 01-08-2004 05:12 PM
