1958 Mercedes Hot Rod on a S10 Frame - Page 32 - Hot Rod Forum : Hotrodders Bulletin Board
Hot Rod Forum : Hotrodders Bulletin Board > General Discussion> Projects/Builds/My Ride
  #466 (permalink)
Old 06-30-2019, 02:54 PM
cseay1949's Avatar
Finally got around to finishing the hood hinge pockets. Cleaning up the driver side hinge mount panel revealed a few rust holes ..
ID:	444727   Click image for larger version
ID:	444729   Click image for larger version
The Following User Says Thank You to cseay1949 For This Useful Post:
MARTINSR (06-30-2019)
  #467 (permalink)
Old 06-30-2019, 02:55 PM
cseay1949's Avatar
.. fixed the rust holes and finished the pocket for the driver side hood hinge.
ID:	444733   Click image for larger version
ID:	444735   Click image for larger version
  #468 (permalink)
Old 07-02-2019, 02:16 AM
fiftyv8's Avatar
Great work, don't stop now you are making some decent progress.
  #469 (permalink)
Old 07-07-2019, 03:37 PM
cseay1949's Avatar
Bolted the headers and h-pipe on to check my clearances. On the driver side the header flange is 1/2" away from the original toe board, while on the driver side it is 2" into the original toe board. I like to keep at least 1.5" of clearance (a 2x4 on it's skinny edge is a good way to set clearance). That way if need be I could have a heat shield spaced 1/2" away from the body and still leave a 1" air gap to the exhaust. As you can see the tri-five chevy engine bay is a bit wider than the Mercedes.
ID:	444911   Click image for larger version
ID:	444913   Click image for larger version
ID:	444915   Click image for larger version
ID:	444917   Click image for larger version
The Following 2 Users Say Thank You to cseay1949 For This Useful Post:
123pugsy (07-07-2019), fiftyv8 (07-07-2019)
s10 hot rod pressurluck Engine 1 07-04-2010 08:22 AM
s10 hot rod pressurluck Hotrodding Basics 1 07-04-2010 06:47 AM
hot rod frame first time fb13 Hotrodding Basics 13 08-15-2008 05:06 PM
Mercedes Benz Hot rod???? Is it ok? Ozzmancomet Hotrodding Basics 13 04-01-2008 04:45 PM
hot rod s10 tonyeng55 Introduce Yourself 8 08-29-2007 11:27 PM
