1967 El Camino rear window repair - Page 5 - Hot Rod Forum : Hotrodders Bulletin Board
  #61 (permalink)
Old 05-01-2016, 06:35 PM
Cool, I was just concerned about that, it didn't look right to me.
The Following User Says Thank You to MARTINSR For This Useful Post:
Chucky5150 (05-01-2016)
  #62 (permalink)
Old 06-16-2019, 09:45 PM
Last journal entry: Dual 13 inch fan install
Holy old topic batman!
So, life has gotten in the way. Worked on the honey-do list, then ended up putting an offer on a new (to us) house. Got the house and spent a year and a half remodeling it just to get to the point we could move in.
I'm going to the welding supply tomorrow and pick up some gas. It's time to get this put back together.
With any luck I wont mess anything up too much.
  #63 (permalink)
Old 06-18-2019, 01:06 PM
Finally making progress. I'm sure there will be mistakes doing this. However, at least it's me who's making them. Took a few minutes to get the welder changed over from flux core to solid wire. Then took some more time looking at pictures from the first few pages, good thing I posted them here.
First time for everything!
Now to change gears and install some flooring.
The Following User Says Thank You to Chucky5150 For This Useful Post:
idrivejunk (06-19-2019)
  #64 (permalink)
Old 06-19-2019, 08:17 PM
Question for you guys:
I am slowly making forward progress on this. I don't know much about working with body filler or have any tools to help with that step. What should I look in to getting to help assist on the next stage on this?
  #65 (permalink)
Old 06-19-2019, 10:07 PM
idrivejunk's Avatar
Grand Prix User
Last journal entry: Last look
Not a lot of tools involved in filler work, nothing expensive anyway unless its nice sanders. Mixing, spreading, and sanding filler looks simple but the learning curve may be infuriating if you are completely green on that. A quarter or half hour of firsthand tutorial demonstration would probably have you ready to start practicing at home. I have not compared any of the bondo lessons on web videos but that would be the next best thing. Youtube has a bunch. Search for "body filler tutorial" and start soaking it in if theres nobody around to show you how in person.
The Following User Says Thank You to idrivejunk For This Useful Post:
Chucky5150 (06-20-2019)
  #66 (permalink)
Old 06-20-2019, 06:56 AM
Good call on the youtube. I learned how to do the brake lines from watching videos there.
  #67 (permalink)
Old 06-20-2019, 06:19 PM
chasracer's Avatar
True Hotrodder
All of the above are good suggestions. I repaired my 66 rear window a different way and it was a little worse than yours. You probably won't like this idea and that's okay but unless you're a very practiced body man you are going to end up with a wavy ***'d mess. That's a long seam no matter where you cut.
My fix was to sand blast the entire area until I had nothing but clean metal, then I had a bottle of metal prep right there and used it generously. After that dried I mixed up Fiberglas bondo. There are two ways to go on this, one is to buy it in a can, you just add hardener as directed. OR, you can mix up your own 50/50 mix of bondo and chopped fiberglas strands. For a beginner, the premix is the better choice. The best thing about this is that once the mix is hard, it is completely water and moisture proof. I kept my car well over 12 years with no issues and about 5 years ago I saw the car again. The window area was still in great shape.
  #68 (permalink)
Old 06-21-2019, 10:24 AM
Maybe next time I'll do it that way. If it gets wavy, I'll write it off as a learning experience.
  #69 (permalink)
Old 06-21-2019, 12:54 PM
Be carefull here. The "bondo" is not waterproof. If you have epoxy primer under it, you have a waterproof barrier but the body filler is not.
John
  #70 (permalink)
Old 08-26-2019, 10:56 AM
This project seems to be taking forever! For better or worse I've made some progress.
Heck Of a learning curve with the Bondo. First time I added too much hardner And it turned to a solid mass on the board. It got a little better after that.
I got a can of the 2 part epoxy primer and that is where stop again as I have to go back to work for a few weeks.
It doesn't look like a pro job. I think it looks fair for someone who has never any body filler / paint before.
  #71 (permalink)
Old 08-26-2019, 10:57 AM
Not sure why this one didn't upload also.
  #72 (permalink)
Old 10-02-2019, 08:49 AM
The final countdown
Getting it to the point of driving it again.
Just got to install the clips for the metal trim that goes around the glass. Overall I'll give it a solid looks ok. Not the best body filler work. At least the panel doesn't look wavy as you look at it. I think the paint came out pretty good for coming out of a spray can.
Next day or two I'll be able to get the glass put back in place.
  #73 (permalink)
Old 10-02-2019, 12:34 PM
idrivejunk's Avatar
Grand Prix User
Having that taken care of makes you feel lots better about your Camino, I'd bet. Get back to enjoying it.
1967, el camino
Rear window repair. ChevChev Body - Exterior 3 02-14-2016 07:16 AM
1967 El Camino rear brake line Chucky5150 Suspension - Brakes - Steering 5 11-20-2012 11:08 AM
Headers for a 1967 El Camino Chucky5150 Engine 2 04-29-2010 11:12 AM
1967 el camino too low? Madmax305 Suspension - Brakes - Steering 2 03-07-2010 01:52 PM
70 el camino under rear window bed trim removal hrd Body - Exterior 0 03-25-2006 12:11 PM
