1969 c10 - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-10-2019, 01:32 PM
Dave1958's Avatar
1969 c10
Bought a 1969 c10 it’s on a later model frame is there anyway to find out what year the frame is , last owner didn’t know
Old 10-10-2019, 07:03 PM
techinspector1's Avatar
Last wiki edit: DynoSim combinations
Wiki Edits: 326
The engine that's in it, did it come with the body or with the frame?
Old 10-10-2019, 08:02 PM
55_327's Avatar
67-72 frames were essentially the same, and used coil springs and 12-bolt differentials on the C10. 73-87 frames were quite a bit different and used leaf springs and 8.5" 10-bolt differentials on the C10.
Another difference: The 67-72 transmission cross members were level, whereas the 73-87s were higher on one side, making dual exhausts kind of a pain to install.
One more: 67-72 upper and lower control arms did NOT use bushings, whereas you should be able to plainly see bushings on 73-87 truck frames.
Old 10-10-2019, 08:49 PM
ericnova72's Avatar
More for Less Racer
The 73-87 Trucks didn't use the 8.5" 10-bolt in the rear until either 1981 or 1982 time frame....all of the 1973-1980 still had a 12-bolt Truck rear.
Old 10-10-2019, 09:43 PM
RWENUTS's Avatar
And the 67-72’s had leafs or coils.
Manual trans frames had a saddle crossmember that the bellhousing bolted to.
Also check rear shock mounts.
Staggered in front and back of rearend on 73 up. Both In front of rearend on 67-72
Old 10-11-2019, 02:00 PM
Dave1958's Avatar
Thanks for everyone’s replies should be able to figure it out from here
Old 10-11-2019, 02:30 PM
Wiki Edits: 326
Thank you for ignoring me Dave. Not a good way to start new on a forum. I had a reason for asking.
Old 10-11-2019, 06:57 PM
Dave1958's Avatar
Sorry tech inspector didn’t mean to ignore you don’t get on the website a lot,as to your question really don’t know if it’s original or not the gentleman I bought it from didn’t know
Old 10-11-2019, 10:49 PM
RWENUTS's Avatar
If you want to dig into your motors origin you can find some pics and charts in here to determine that.
https://www.mortec.com/
And to further the search if you look for a flat pad in front of the passenger side head, the info there will possibly give you a suffix code that is in the list in here.
Chevy VIN, Trim Tag and Drivetrain Information & Decoding
Old 10-12-2019, 06:07 AM
75gmck25's Avatar
Last journal entry: Engine replacement
If its a 73-87 GM squarebody truck frame it will also have the VIN number stamped in a couple of locations. The most likely is on top of the passenger side frame rail, but its often stamped so far back that its under the cab. Once you find the VIN you should be able to cross-reference to a year and model.
Another option is to look at the GM truck frame reference spec sheets and compare dimensions. https://www.gmsquarebody.com/ has the information you need.
Bruce
Old 10-12-2019, 09:36 AM
RWENUTS's Avatar
Another tell-tale on the frame is the post 72 has the brake proportioning valve located on the crossmember below the rad.
Old 10-12-2019, 10:53 AM
poncho62's Avatar
Last journal entry: 77 Ford
Wiki Edits: 5
Posting a couple of pictures of the frame in the engine area and a shot or two under the truck might help the guys here to judge better.
I wonder if common sense will ever make a comeback?
