1970 chevelle quarter panel replacement - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-12-2014, 08:47 PM
Looking for some advice on how to get my new quarter panels on my 1970 Chevelle. After getting the old bondoed panels off, I quickly realized I had a much larger issue I was going to have to tackle. As you can see, the frame is a bit bent. I always noticed that the left side of the rear bumper sat lower than the right, now I know why. The car is backed in at an angle, so it looks a lot worse than what it truly is. What do I need to do to get this fixed? Please help.
Old 06-13-2014, 05:46 AM
deadbodyman's Avatar
Last wiki edit: Stripping paint
Wiki Edits: 11
You need a good frame man.....Or a new frame...try unbolting the rear body mount bolts to see if the body springs back where it should be ,if the body stays down then the inner structure of the 1/4 is also bent and will need to be replaced....If thats the case,Its a big job that requires a bit of experiance
Old 06-13-2014, 09:10 PM
carolinacustoms's Avatar
Automotive Extraordinaire
Mike is exactly right, you need to get the frame right before you hang any panels or you will be in for a world of headaches. If you're floor is level, you could likely fix the frame yourself, but the best option is to find a local frame shop or collision shop with a frame machine to get it back to factory specs, then you can start on the body.
Kelly
Old 06-14-2014, 03:33 PM
Too Many Projects's Avatar
Collector of "someday" cars
Last journal entry: continued
Car has most likely been hit in the rear and the frame kinked over the axle. It will have been pushed forward on that side too and have a diamond in the frame.
As said, it needs to be corrected now before any further work on the body. Too bad you didn't notice this before tearing it apart. You could have driven it to a shop...
quarter panel replacement 81camaro1 Body - Exterior 7 10-06-2013 09:39 PM
Datsun 510 Quarter Panel Replacement rcmonza Body - Exterior 5 02-06-2011 07:06 AM
67 Mustang Quarter Panel Replacement Morgan22 Body - Exterior 8 07-16-2010 02:30 PM
Quarter Panel Replacement jakejake1966 Body - Exterior 2 07-05-2006 07:56 PM
quarter panel replacement 38chevysedan Body - Exterior 3 10-30-2005 07:58 PM
