1974 nova brake lines - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-20-2018, 05:08 PM
Hello all, Working on a 1974 Chevy Nova I currently got the disc brake kit for the front and leavening the drums in the rear. I am also replacing all the brake lines. My question is what size brake line should I use I put the 3/16 line on the back axle and then realized that the fitting in the center brake hose is bigger. Should I use a 5/16 brake line from front to the rear or just use 3/16 across the whole car or get the fitting adapter for the center hose and the proportional valve. Thanks for any help Mike
Old 07-20-2018, 05:21 PM
techinspector1's Avatar
Last wiki edit: DynoSim combinations
Wiki Edits: 326
Some fellows will use 1/4", but 3/16" is all you need across the entire system.
Old 07-20-2018, 05:23 PM
astroracer's Avatar
Last wiki edit: Crankshaft Coalition Wiki
3/16th's fine. Do not go to 5/16th's, too big, and the brakes will always feel spongy.
Check into Nichol/Copper line. Your parts store should carry it. Ni/Cop is much easier to flare and bend.
Mark
Old 07-20-2018, 05:27 PM
Thanks for the response guys I was just looking on Amazon and found the 3/16 copper nickel brake line with fittings that is like 15 dollar cheaper then the steel lines at the local parts store maybe I will buy that brake line it is only 37 bucks.
Old 07-20-2018, 06:04 PM
ericnova72's Avatar
More for Less Racer
Stock system with front disc brakes would have been 3/16" up front, with 1/4" from master cylinder or combination valve to the rear distribution block on the top of the axle housing, and 3/16" split from there out to each rear wheel.
The Following User Says Thank You to ericnova72 For This Useful Post:
joe_padavano (07-23-2018)
Old 07-23-2018, 02:39 AM
Another quick question could I get away with a single flare lines or should I do double I have never done a double nor do I have the tool for a double but obviously I can pick one up and do the double.
Old 07-23-2018, 04:33 AM
astroracer's Avatar
Double flares are what you need to do. I have been using this flaring tool from CPP for a few years now. It has never done a bad flare. For the price it can't be beat.
Classic Car and Truck Brake, Steering and Suspension Parts
Mark
Old 07-23-2018, 08:24 AM
Old(s) Fart
Last wiki edit: Wheelbase database
^^^THIS. Of course, the actual diameter of the line is irrelevant once you bleed the brakes. 3/16, 1/4, 5/16, it doesn't matter. So long as the line is not so small as to become an orifice, the wheel cylinders will neither know nor care the diameter.
Be aware that GM used non-standard flare nut threads on the various lines to preclude incorrect connections on the assembly line. If you buy generic parts store brake line, the standard fittings won't necessarily be the right size. Most of the tubing vendors sells kits of these oddball flare nuts.
Old 07-23-2018, 08:38 AM
This is the set I bought
Name:	Screenshot_20180723-103720_Amazon Shopping_1532356683257.jpg
Old 07-23-2018, 08:40 AM
Cant post a picture for some reason
Old 07-24-2018, 09:07 AM
PHWOARchild's Avatar
Does the copper stuff come in straight lengths? So far all I see is it coiled up, which bothers me visually since it is difficult to straighten out the way I like.
Old 07-24-2018, 09:15 AM
Old(s) Fart
Or, just use real brake line. I just don't trust that Cu-Ni stuff. Get real tools to straighten, bend, and flare the lines. With correct, high quality tools, this is easy.
Old 07-24-2018, 09:17 AM
astroracer's Avatar
It only comes in coils as far as I know. I made a roller to straighten it. The tools can be bought from Eastwood and a few other places if you can't make one.
It works very well. This is steel brake line and it was arrow straight after three passes...
Mark
And Joe, there is no need to shy away from this stuff, it works very well and is being used by OEMs.
Old 07-24-2018, 09:21 AM
Old(s) Fart
Yes, those roller straighteners work amazingly well. I got mine from Inline Tube and it does wonders with coiled stainless brake line. In fact, it's a great way to re-straighten pre-bent lines after they bend them in half for shipping.
Old 07-24-2018, 09:44 AM
astroracer's Avatar
Yes they do. I have about 15 dollars into building mine. This pic is at the end of a 20' coil I straightened for my Astro project. You can see the end of the coil in the right hand corner of the pic.
Here is the line supported by a few roller stands.
This pic is right before the last roll to get it perfectly straight. You can see it is just a bit warbley.
I straightened the entire roll in less then 10 minutes. Steel takes a bit longer as it needs more thru puts to hold the shape.
Mark
1974 Nova Fuel lines Fasazu Engine 2 10-05-2009 01:33 PM
1974 nova jerry meadors Engine 3 09-13-2006 03:02 PM
1974 nova oil pan no2nosss Engine 5 03-29-2006 06:46 AM
1974 chevy nova stevenc6137 Introduce Yourself 3 02-17-2006 04:56 PM
1974 Nova rebuild bblaser Engine 4 08-29-2002 10:34 PM
