1975 Nova Rear End Swap - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-08-2018, 12:53 PM
Hello All,
I am new to the group. I have a 1975 Nova 4 door 6 cylinder. I am LS swapping the car, and wanted to beef up the rear end. A buddy of mine has a rear end out of a 1986 Trans Am, and I am wondering if I could make that work? Is mid 80's gm rear end's compatible with 4th gen Nova's? Thank you for any help on the matter.
Old 11-08-2018, 02:02 PM
big gear head's Avatar
High Performance Rear Ends
Your '75 Nova should have the 8.5 10 bolt rear end, which is MUCH stronger than the little 7.5 that was used in the '86 Trans Am. Even if it wasn't, that swap would be much more trouble than it's worth. Build the one that you have.
The Following 3 Users Say Thank You to big gear head For This Useful Post:
Crosley (11-08-2018), gentry.ericj (11-08-2018), joe_padavano (11-08-2018)
Old 11-08-2018, 02:23 PM
Thank you, then that is exactly what I am going to do. I thought I was on to something, and it sounds like I was, a big fat headache. Thanks again for the advice.
Old 11-08-2018, 03:04 PM
ericnova72's Avatar
More for Less Racer
some info you may be interested in here:
www.novaresource.org
https://novaresource.org/axle.htm
Old 11-12-2018, 12:57 PM
take a good look at that rear in your nova??? Most six banger nova (75-79) didn't have 8.5. All the those year of nova with v-8 had 8.5. Every time i go to car show, i look for those novas, and check them out. I have a 77 councours nova hatchback with the 8.5. I was told that there were some that got the 8.5, but it was rare. Don't know if that is even true. Look up a picture of it to see if it matches yours.
Old 11-12-2018, 02:18 PM
It's always a good idea to check things out before getting started. The '75 should have the 8.5 no matter what engine was installed, but who knows what has been changed over the years. It could even have a first gen Camaro 8.2 in it.
Old 11-13-2018, 08:23 PM
fast68's Avatar
likes chevy trucks & boobies
the F body rear would be a downgrade unless it is maybe a borg warner 9 bolt but those werent very common. and a 8.5 is still most likely stronger than that too. the third gen F bodies went to crappy small light weakling coils rear with single stamped steel bar from trans tail end to axle diff housing. totally one-off unique design.
nova, rear end, swap, trans am
1975 nova 8.5 rear end knottyboy132 Transmission - Rearend 6 02-21-2012 03:57 AM
1975 Trans Am 4 link rear end Ginger_ninja Suspension - Brakes - Steering 2 02-13-2011 02:30 PM
1975 8.5 rear end camino_man Transmission - Rearend 6 09-18-2004 05:32 AM
1975 nova LN for sale rockslide Hotrodders' Lounge 1 01-12-2003 09:07 AM
1975 Chevy Nova SS pinstriping kalong12 Body - Exterior 3 11-04-2002 02:28 PM
