1979 camaro tail light problem - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-01-2014, 04:02 PM
Last journal entry: 1979 Camaro Berlinetta
I have a 1979 Camaro Berlinetta. When I turn the lights on (parking or head lights) the drivers rear brake light comes on and the drivers side blinker blinks slower then the right and if the lights are on the drivers side blinker just turns on but does not blink. Any help? Thanks
Old 07-01-2014, 05:08 PM
lakeroadster's Avatar
Hot Rods are Built, not Bought
Last journal entry: Lakeroadster's '31 Model A Tudor
Might be a ground issue. Try running a temporary ground wire from the negative terminal of the battery and then use it to see if the problem goes away when you touch the temporary ground to the light socket housing.
If that fixes it run a dedicated ground wire from the socket to the frame.
Old 07-01-2014, 10:44 PM
Have you checked the signal flasher yet? Also check your bulbs filaments. Like was said early check the light socket and make sure it is grounding to the taillight panel. If the sockets look to be in bad shape replace them with new ones.
Old 07-02-2014, 06:43 AM
Last journal entry: Still running strong
Bulk head connector is a problem on those. I know, I have a 78 Z28. If your grounding to the core support , its not grounded very well. I ended up running a 10 ga. wire from the frame to the core support. You'll get a voltage loss from the bulk head connector. I took mine apart an did my best to clean all those male & female connections but I still only had 10 1/2 volts at the bulbs. Mine were dim but there brighter now.
Old 07-02-2014, 08:55 AM
1971BB427's Avatar
Pack those bulkhead connectors with GE Silicone Grease. Keeps moisture out, and makes a better contact point.
On the OP's question; a poor ground can create all sorts of problems and feedback issues.
Old 07-02-2014, 01:50 PM
T-bucket23's Avatar
Last wiki edit: Engine basic condition - how to check
Wiki Edits: 26
Could be as simple as a bad bulb, filaments touching. You need a test light and some time to track the issue down. pull the bulb and check the two contacts at the bottom of the socket. With the lights on one should have power and the other shouldn't. If that looks ok then either the socket is somehow broken or the bulb is no good.
If with only the lights on you have power to both pins then there is a wiring issue somewhere.
I have seen people put the wrong bulbs in and cause issues like this
Chet
Old 07-02-2014, 04:19 PM
So how I got confessed between the front an rear. The rear break lights & blinks, IDK........
One thing I know for sure if all the wiring were replaced for the all the rear lights everything would work 100% better. Get your voltage meter, turn on the lights an look at the voltage your getting. 9 volts? 10 volts? Causes for this, bad connections, bad grounds, brittle wire, thin wire. I was at the local pick n pull not long ago an notice that Volvo has a seperate fuse panel that's in the trunk for everything that's electrical in the rear of there cars. Good idea.
brake light, camaro, electric, lights, wireing
67 Camaro Tail Light problem Toddtex Electrical 4 11-04-2012 03:05 AM
LED tail light problem rusty duck Electrical 8 10-18-2012 10:07 PM
87 cutlass tail lights and dash light problem theguesswho Electrical 2 09-09-2012 08:05 AM
tail light problem cares Electrical 2 04-05-2008 10:17 AM
Bonneville Tail Light and Turn Signal Problem darksider Electrical 3 01-09-2008 01:30 PM
