1979 gmc k25 gvwr - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-18-2018, 06:07 PM
EragonSuperH's Avatar
I invent stupid usernames
1979 gmc k25 gvwr
I recently purchased a 1979 GMC K25 and I'm trying to figure out the GVWR. There were 3 options for that model and year, which were 6800, 7200, and 8400. IIRC the 6800 was only available with the standard rear brakes and mine has the HD 13 inch rear drums. It also has 7 rear leaves which leads me to believe it might be 8400 but I want to make sure. It also has 3.73 gearing and a 14 bolt full floating rear with a Dana 44 front. Any help is appreciated.
Old 12-18-2018, 09:02 PM
If you have vacuum breaks then you have the 6800 rating.
If you have the "HD power breaks"= Hydroboost. Then you have the 7500 or 8400 rating.
Due to your rear axle ratio I would go with the 7500 rating.
I believe the 8400 rating was only offered with 4.10 or 4.56 gearing and a few extra codes.
This is for 78 but is a good reference for you.
https://www.gmheritagecenter.com/doc...olet-Truck.pdf
Page 13 and 14 for GVWR.
Old 12-18-2018, 09:07 PM
I have that whole PDF for the 79 models. It has vacuum brakes, and 13 inch drums (15.5" outside diameter). Are you absolutely sure that the HD power brakes means hydroboost? 3.73 gearing was the standard gearing at all gvwr levels for all 4x4 3/4 tons with a 350, other ratios were optional. This is based on the PDF
Sent from my VS996 using Tapatalk
Old 12-19-2018, 04:23 AM
I know in the 2wd models the hydroboost moves up the rating up then the ratio moves it up more. Rims also play a part as well as motor.
Am I 100%? No. This is one of those things that is vague and you will get various weights. Best to be safe.
The gvwr is not the gvcw. You can still tow a good smount.
The Following User Says Thank You to cerial For This Useful Post:
EragonSuperH (12-19-2018)
1970 GMC k25 gen 1 chevy 350 GMCjimmy Engine 0 09-27-2014 12:00 PM
700 r4 88 gmc tranny- 400 turbo 87 gmc tranny ? limp'n-gmc Transmission - Rearend 6 02-15-2011 08:58 PM
need help changing out sterring collumn on a 1979 gmc high sierra half ton 4x4 81scottsdale400 Suspension - Brakes - Steering 4 10-10-2010 11:14 PM
Camshaft/exhaust selection for '75 GMC K25 75gmck25 Engine 10 10-26-2008 09:24 PM
97 gmc 1500 97 GMC 1500 Internal transmission squeak Longbox262 Transmission - Rearend 5 06-25-2008 06:41 PM
