1994 Chevy 1500 - Doesn't Move Forward On Its Own When in Drive - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-29-2019, 09:12 PM
lt1silverhawk's Avatar
"But how do it know?"
Wiki Edits: 132
Hi All,
Quick question: when I put the transmission into drive and take my foot off the brake pedal, the truck never moves forward under its own power. It takes a bit of pressing the accelerator pedal to get it going, but I assume that's just because it is a big heavy vehicle.
Is this pretty normal? Or am I wrong in thinking that the engine is lacking power somewhere?
Thanks in advance!
Old 04-29-2019, 10:14 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
It means you have the proper stall convertor. the truck should not move until you give it a bit of gas...
Sam
The Following User Says Thank You to OneMoreTime For This Useful Post:
lt1silverhawk (04-30-2019)
Old 04-30-2019, 05:05 AM
123pugsy's Avatar
Rod...from a Chrysler?
Last wiki edit: Metal shaping
Last journal entry: SEAM SEALER
Wiki Edits: 29
I would think the brakes are tight.
The Following User Says Thank You to 123pugsy For This Useful Post:
Old 04-30-2019, 06:47 AM
55 Tony's Avatar
It could mean your transmission is slipping. Does it seem to go a little easier as it warms up? Or cycle it from D to R back and forth a few times and see if it *grabs* better. My 2000 3500 van with only 100,000 miles on it started to slip on cold days if it sat more than a few days. I added a bottle of snake oil (trans X (?) blue bottle) and the problem went away, for now. I know this means it needs seals, but I'll see how long it keeps going. If yours is slipping, try the snake oil ASAP or you will wear out the clutches, then a rebuild is needed now rather than later.
On a completely different tangent, the fan clutch in my van grabs like heck when first started and it sounds like you are really revving the engine when you just touch the throttle. That too goes away in a minute or two of driving. Been like that from new.
Then again, it could be just like Sam said, normal. Mine is on the loose side but on a flat road it will move forward a little at least without touching the throttle.
The Following User Says Thank You to 55 Tony For This Useful Post:
Old 04-30-2019, 01:31 PM
poncho62's Avatar
Last journal entry: 77 Ford
Wiki Edits: 5
Does the trans seem to operate normally other than that?......Shift properly etc?
Maybe your idle is just a bit lower than you are used to.
The Following User Says Thank You to poncho62 For This Useful Post:
EragonSuperH (05-01-2019)
Old 04-30-2019, 06:18 PM
Wiki Edits: 132
Sam
Hey Sam ,
Interesting, learned something new today. Thanks!
Hey Pugsy, long time no talk! How have you been? Is your ride finally done?
I don't think its the brakes, but I'll check them out.
Hey Tony,
I think it does "run better" once warmed up. But I hardly ever drive it so I never notice. Plus, I have a habit of letting it warm for a bit before driving off. On the next drive, I'll pay attention.
I don't think kine has a fan clutch.
Hey Poncho, Hope all's well!
The transmission has been having issues shifting into and staying in 4th (more info here and here). Otherwise it seems to be fine and shifts rather smoothly. I just did a full tune up, but haven't had a chance to run it on the freeway to see it made a difference.
Old 08-06-2019, 12:08 PM
Wiki Edits: 132
Just wanted to post a quick update.
The truck was recently sold, and the new owner took it to a mechanic shop where they discovered that the first gear was not functioning due to a bad solenoid.
The Following 2 Users Say Thank You to lt1silverhawk For This Useful Post:
123pugsy (08-06-2019), Excellenceautosoluti (08-06-2019)
Old 08-07-2019, 08:22 AM
454 Rattler's Avatar
NEVER SATISFIED !!
Thanks for that up date. It's good to know.
454 RATTLER
Old 08-07-2019, 12:29 PM
55 Tony's Avatar
I had a work van of that vintage that lost either 1st or 2nd and Overdrive. The dealer found no solenoid signal coming from the computer and installed a new one, which burnt out right away because the solenoid was shorted! Had to wait again for a second computer.
That dealer service center sucked. I had the van to them 5 or so times for a vibration in the rear, more so when braking. First turning the drum, later replacing the drum, then I told them to replace the axle and get it over with. It took a couple more trips there to get a new axle and all was fine. They said the runout on the axle was within GM spec but changed it anyway. I had been giving them good ratings to the GM questionnaires, but after that I let them have it. I don't recall what I went there for again but they were all calling me Sir. LOL
350, 4l60e, chevy, chevy silverado, transmission
chevy 4l60 4wheel drive to 2wheel drive?? briansansone Transmission - Rearend 5 06-17-2015 06:16 PM
Engine swap on a 1994 Chevy 1500 4wd stfinney Engine 7 04-14-2015 06:20 AM
1994 Chevy 1/2 ton 4 x 4 trans problems Alaska_Man Transmission - Rearend 2 06-04-2012 09:01 AM
'95 Chevy 1500 ring and pinion matt167 Hotrodders' Lounge 2 11-02-2010 10:01 AM
1994 Chevy k1500 tranny problems rebel till death Transmission - Rearend 2 03-22-2009 10:35 AM
