1996 - L31 Vortec Rebuild - Flat tops or Dish stockers? - Page 6 - Hot Rod Forum : Hotrodders Bulletin Board
  #76 (permalink)
Old 03-05-2016, 11:25 AM
I started a thread similar to yours and ended up going with Keith Black KB Performance Pistons KB193-030 - Free Shipping on Orders Over $99 at Summit Racing I went with the 9.5-1 static ratio in the end after much debate considering I have cast vortec heads and the best fuel locally is 91 octane.
  #77 (permalink)
Old 04-05-2016, 05:03 PM
Ok guys parts are here and i'm really pumped to get this project on the road.
i appreciate all advices and posts here on this thread.
Here's what i got (Heads and cam are bought and waiting to be installed)
1 - Camshaft Bearings: 5 Bearings
SH1349S
Contents:
SH-1349 Position 1
SH-1350 Position 2,5
SH 1351 Position 3,4
they have
to be installed in the determined position.
2 - Connecting Rod Bearings "EngineTech" BB253JSTD
3 - Main Bearings "EngineTech" BC296JSTD
4 - A great piston & ring kit which includes:
Chevy 350 Flat top 2 relief
Chevy SBC 350 Flat Top Pistons Moly Rings Kit 030 355 | eBay
A - Sealed Power/Speed Pro Hypereutectic Pistons H631CP30
B - Mahle Box of Rings 40564CP.030
Pistons came with the pins and safety pins or clips, they look very nice.
Remembering that i will bore my block .30 over
the piston spec decal on the box says:
Minimum clearance: 0.0010
Skirt Size: 4.02875 +/- 0.00025 inches (What is +/- 0.00025 inches???)
Measuring Point: .0010
So this is what i will tell the machinist this week.
Piston diamteter (skirt): 4.02875+0.0010 (min clearance)
They will have to bore to 4.02975
Am i right?
I'm using the same "formula" i did when my L98 was rebuilt back in
2008 and it runs great 8 years after
Later i will have to check ring gap, the diameter says : 4.0295" (102.35mm)
Thanks!
Sammy
  #78 (permalink)
Old 04-05-2016, 06:09 PM
BuzzLOL's Avatar
Cars, Trucks, Boats
Looks good... I love 2 eyebrow flat tops... love that kit price, also... I would give the pistons to the machinist... he may want to mark them #1 - #8 and finish hone each bore precisely for a particular piston... depending on how fussy he/she is...
+/- 0.00025" means they tried to hold the sizing on each piston to no more bigger or smaller than spec size within 1/4 of 1/10,000"... but, like I said, your machinist may want to verify if they managed to do that...
  #79 (permalink)
Old 04-05-2016, 06:12 PM
Thanks Buzz!
  #80 (permalink)
Old 07-08-2016, 03:44 PM
Hi everyone, update time, the block is back from the machine shop
and they did a great job, we pressure washed later and we are ready
to start assembling, bearings are installed but i have a doubt about lock rings only.
Pistons are : Sealed Power/Speed Pro Hypereutectic Pistons H631CP30
We are using the stock rods, well, we have the piston groove to install them wire locks, but ...last time i bought pistons they didn't come with those locks.
i think i must use them, or should we avoid them?
Since the stock rods are pressed.
Just asking to be on the safe side.
Thank you !!!
ID:	309753   Click image for larger version
  #81 (permalink)
Old 07-08-2016, 03:47 PM
BuzzLOL's Avatar
Cars, Trucks, Boats
Tight press in rods don't need the snap rings in the pistons... they just supply them in case you have the loose fit floating pin rods...
  #82 (permalink)
Old 07-08-2016, 03:49 PM
So stock rods are non floating type, right?
I have never worked with aftermarket floating rods.
So if we use them it's overkill?
Thanks again Buzz
  #83 (permalink)
Old 07-08-2016, 04:30 PM
BuzzLOL's Avatar
Cars, Trucks, Boats
Most stock rods are press in, but some high performance engines came stock with floating pins...
Using the rings with a press in rod might push the piston to one side if pin not pressed into the exact correct position...
  #84 (permalink)
Old 07-08-2016, 04:31 PM
Thanks, we'll leave them out then.
  #85 (permalink)
Old 07-08-2016, 08:54 PM
Here's the stock L31 Camshaft (Short pin)
and the Hotcam with the Long pin.
i cannot find the correct length for the L31 pin
and the stock casm is sold.
Should i cut it or press the dowel in?
Thanks
  #86 (permalink)
Old 07-11-2016, 01:37 PM
Thanks
From GM about the LT4 Hotcam
"For LT1 and L98 engines for MY 1995 and older, the dowel pin at the end of the cam should be pushed in so extension from the end of the cam is 0.30" + or -, the same as the production part. For 1996 LT1 and LT4 engines 1996 and newer the dowel pin is in the correct position, extending 0.620" from the end of the camshaft."
I'd just tap it in as it doesn't need to stick out so far as it doesn't drive the Optispark distributer as it is absent in the 1996-2002 L31 350 application.
On the L31 that dowel is just used to correctly align the camshaft sprocket on the end of the camshaft.
peace
Hog
  #87 (permalink)
Old 07-11-2016, 01:40 PM
True, Thanks Hog!
  #88 (permalink)
Old 04-12-2017, 07:33 AM
Long time no see, the truck is alive and running great!
We finally aborted the 411 mission since we almost got scammed by certain tuner.
We ordered a Blackbox from PCMForless and we are still running the stock pressure spider upgrade
we were recommended a 36lb spider for the tune but the stock runs fine, we removed EGR
the truck runs fine, it's way quicker and screams with the 3600 Yank when you mash it but it's
not that impressive violent, we know that we are still using the stock intake and spider so we have two options here :
1 - Get the 36lb Spider and check it out and stay there.
2 - Make a plan for a ramjet or selftune intake?
We have time now that the truck is running pretty good, we can plan and then execute.
I will record a video of the new sound and feel.
Thanks
  #89 (permalink)
Old 04-12-2017, 12:14 PM
Originally Posted by hcompton View Post
One of these even with the stock throttle body should move a lot more air and not log jam at higher rpm.
https://speedmaster79.com/pce1481002...anifold-satin/
early ls throttle body is good choice with cable throttle and larger bore gm tps.
q45 is a nice large one 95-104 iirc MM throttle body. These do the trick. both may require some mods to make work the stock tb might do the trick at first. maybe open it up a bit with a port. I would bet a few modes to the stock tb would help then upgrade when the tune is stable. If dyno tuning then do all the upgrades at once maybe even buy a big after market tb I think the 105 mm can be had in the $300 range.
X2 this is a great way to go rather than messing around with the miserable GM production injection system on the L31s.
Bogie
  #90 (permalink)
Old 04-12-2017, 01:14 PM
If the OP still has Vortec heads....I don't think that manifold is gonna fit? Its listed as 1957-95; not sure how it doeals with the mid 80s bolt angle change either?
l31, rebuild, sbc, vortec, yukon
1996 L31 Vortec - Brown & Black heads? - Pics Calderone Engine 17 01-04-2016 11:16 AM
flat tops in vortec / LT4 cam + shim gaskets Fstarocka Engine 7 06-25-2015 06:57 PM
SBC 383 with 64cc Vortec heads and flat-tops cris well Engine 4 09-30-2011 12:41 PM
blown (L31) 1996 c2500 transman228 Engine 2 02-27-2011 06:10 PM
Difference Between dish and flat piston Parisienne70 Engine 3 02-15-2005 10:10 PM
