2 part Epoxy primer on an oil pan? - Hot Rod Forum : Hotrodders Bulletin Board
Hot Rod Forum : Hotrodders Bulletin Board > Tech Help> Body - Exterior> Paint
Old 03-26-2016, 09:49 AM
Last journal entry: Still running strong
I have some left over 2 part epoxy primer that I'd like to spray on my new oil pan, then high heat rattle can on top of it. Can the epoxy live & not peel off?
Old 03-26-2016, 10:13 AM
Shouldn't be a problem ..
dave
The Following User Says Thank You to 2old2fast For This Useful Post:
dogwater (03-26-2016)
Old 03-27-2016, 07:09 AM
deadbodyman's Avatar
Last wiki edit: Stripping paint
Wiki Edits: 11
just do a little extra prep and it'll never come off. the paint however ,That's a different story ,if its not 2 part its not solvent resistant
Old 03-27-2016, 09:15 AM
astroracer's Avatar
Last wiki edit: Crankshaft Coalition Wiki
You don't need "high heat" paint to shoot the pan. Anything will work. If you want to use body color go ahead. Even cheap black rattle can enamel will live just fine. The only engine parts that get hot enough to burn off paint are the headers and exhaust port area's on the heads. Anywhere else regular paint will live just fine.
Like deadbodyman said prep is key so prep it well and you will have no issues.
Mark
Old 03-27-2016, 11:10 AM
I put 6 of those Neo denmium magnets inside of the pan an slosh around some paint thinner inside the pan, magnets pick up a bunch of debris then did it again with purple power but did the outside also, magnets still pick up debris but not as much. Sanded the outside with 320 then another wash inside & out. Very little powder fine metal left inside this time. Used the HF purple hvlp gun to spray 2 yr old epoxy/catalyst, I was worried it might not do well being its age but besides taking over an hour to dry it did a its job. I let it sit out in the sun a few hours then put 3 coats of VTH engine paint over it. Won't need it for a couple of weeks. First time in over a year to use a hvlp gun. Since it a el cheapo gun I ingraved the settings I was using when I was painting the Camaro on the handle.
Old 03-27-2016, 12:32 PM
Yeah let's make something clear here, the trunk on a black car in the sun in Phoenix Az is going to be hotter than that oil pan! You don't need any "high heat paint" on any part of that engine realistically. It's going to burn right around the exhaust ports with anything you put on it and the rest will be just fine.
The Following User Says Thank You to MARTINSR For This Useful Post:
dogwater (03-29-2016)
spraying epoxy primer over epoxy primer 65 f-100 restore Body - Exterior 11 12-07-2013 01:37 PM
What is the difference between singe stage epoxy primer and 2 stage epoxy primer rusthater89 Body - Exterior 16 06-01-2012 09:06 PM
Flash rust OK under epoxy? SPI epoxy primer, Transtar 6131, or PPG Shop Line? off2wildblue Body - Exterior 2 07-29-2010 08:53 PM
Epoxy Sealer-Primer With 2K Build Primer on top kilgorq Body - Exterior 4 04-29-2008 04:30 PM
can i spray epoxy primer over etching primer without sanding? wickiewicked240z Body - Exterior 1 08-29-2006 09:07 PM
