2 part seam sealer recommendations - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 04-18-2018, 02:51 PM
John,
I was looking at this very thing several weeks ago.
You've probably already read it, but just incase you missed it, there was another seam sealer thread on here that was interesting: https://www.hotrodders.com/forum/seam...se-182420.html
Note that (as of a couple years ago) Barry (I believe the SPI guy) likes SEM.
SEM stood behind their product for one guy:
Looking for a seam sealer. - The 1947 - Present Chevrolet & GMC Truck Message Board Network
To me that says something that they didn't weasel out of it when he could prove that he did everything correct.
I don't remember reading anyone else that had a bad experience with the SEM 2K sealer products that wasn't a direct result of terribly incorrect application.
7oz is ~200mL, and amazon shows a couple manual applicator guns in the ~$50 range. Would the plungers be the correct spacing and diameter for the SEM cartridges? I don't know.
The Following User Says Thank You to cowboy_dan For This Useful Post:
John long (04-24-2018)
  #17 (permalink)
Old 04-18-2018, 03:10 PM
Here is an interesting image I just found in "tech tips" on the Evercoat site.
http://www.evercoat.com/?d=2&dt=70&w=us
And of course these companies usually have good communications with their customers. I emailed and got this part number for the tips. 100817
Yes they ARE available.
LOL, Thanks Brian. I actually found them listed on the web site you posted above. That site also explained how to store the unfinished cartridge.....pretty cool. The friend that repainted my 47 Ford conv has a SEM gun that will handle both the SEM and 3M cartridges. Steve said he had not ised it for 12 years and I could keep it as long as I need it. They are so much cheaper than the Evercoat Maxims, that is the route I will probably go.
This has been a real educational process. I have enjoyed learning more about what is available, both types and manufacturers. I'm beginning to feel a little smarter.
One other question guys. With the old single componant sealers, you could smooth them with your finger dampened with a little wax/grease remover. Does that method also work with the two componant epoxy based seam sealers?
John
  #18 (permalink)
Old 04-18-2018, 03:21 PM
And the "Basics of Basics" on seam sealers.
Seam Sealers - Autobodystore
  #19 (permalink)
Old 04-18-2018, 03:22 PM
Sorry, didn't realize you had already posted this from another site.
  #20 (permalink)
Old 04-18-2018, 05:41 PM
idrivejunk's Avatar
Grand Prix User
Last journal entry: Last look
Originally Posted by idrivejunk View Post
Oh, bonus tip... while it may be out of the manufacturer's intended context for usage a short window exists when it can be tooled with a brush or smoothed with a gloved finger but work fast and lubricate with wax and grease remover.
John
See above. Yes but only for a short time. Work small sections. The stuff is most pretty when applied with a spreader, in my opinion. Dries shiny and you just scuff it then. You can shape a spreader to match a spot too, like a stepped overlap or if you want a tiny proud bead. I suggest priming over the 2K seam sealer for best results.
The Following User Says Thank You to idrivejunk For This Useful Post:
John long (04-18-2018)
  #21 (permalink)
Old 04-18-2018, 05:45 PM
idrivejunk's Avatar
Grand Prix User
John if you'd like pic examples of how it looks brushing and spreading it, say so.
  #22 (permalink)
Old 04-18-2018, 06:52 PM
Thanks Matt. Brian postd some examples on his tutorial and the SEM web site had a good video. I also wathched bunch of Youtube videoes......Including some by some real hacks.
I am happy to look at any examples as well As listen to advice but I do think I have a pretty good idea of how to proceed. I don't want to brush it. I will either use my finger or make a profile out of a spreader.
I have always liked SEM products. As far as you guys know am I ok to order SEM 2k since I have their gun?
John
I want to seam seal the flange around the firewall but need it to look neat and clean.
  #23 (permalink)
Old 04-18-2018, 06:55 PM
If you have any with a shaped spreader, that would be cool.
John
  #24 (permalink)
Old 04-18-2018, 07:05 PM
idrivejunk's Avatar
Grand Prix User
Probably not on that, but I saw some brushed stuff when I found that gun pic. Sounds like you're covered, I have just been replying on the phone and not looking at links. You will do fine, sir.
  #25 (permalink)
Old 04-24-2018, 02:23 PM
496CHEVY3100's Avatar
Last journal entry: 53 ad3100
Just my .02c..but I normaly run a 1in wide masking taoe down each side of the seam then brushe the sealer when it starts to dry I use a b
bondo spreader and smoth the sealer,,then when Almost dry remove the tape,,then you have Perfect straight and uniform edges,
I do sand my seam sealer with 800 and DX330 or equivlant,
don't know if it helps but it is the way I was shomn,Maaany moons ago,
  #26 (permalink)
Old 04-24-2018, 03:40 PM
LOL, I definitely will tape along the seam. I am way to sloppy not to take that precaution. I probably will do a couple of practice runs too since this will be in such a conspicuous location.
John
  #27 (permalink)
Old 04-24-2018, 03:43 PM
Originally Posted by cowboy_dan View Post
John,
Dan, I just re-read this thread and realized I had not responded to you contribution. I apologize and thank you for your post and sound advice. I appreciate all who contributed.
John
  #28 (permalink)
Old 04-25-2018, 06:35 AM
John
No apology necessary.
We all miss things once in a while, or forget.
If it weren't for my poor memory, I'd never enjoy the pleasure of finding my keys, again.
  #29 (permalink)
Old 05-01-2018, 11:05 PM
put up or shut up
I have that SEM gun. It will work with the 3M cartridges. Just make sure he has the right plungers screwed in. It should come with a few different size ratios but 1 to 1 is what you want. SEM seam sealer is pretty solid. for seam sealing hoods and doors I'm instructed to use "easy sand". It's a plastic repair we use for bumpers. It lays out smooth with plenty of flow. Sticks well too. I wouldn't waste my time with the 2 part sealers on the underside or floors. Use 1k for that otherwise you'd be spending a couple hundred on just seam sealer. The 1k product is great for when panels have a huge gap from factory. The 2k is good for exterior panels. The seam sealer that flows are great for run channels as that always has to be really smooth as long as you make a tape dam to collect the sealer that wants to drip on your quarter. Regular 2k seam sealer elsewhere.I'd just get the SEM. A lot cheaper than Evercoat or 3M. SEM has some pretty solid products and are getting better.
Seam sealer NOVA1958 Body - Exterior 1 09-15-2011 09:26 PM
Seam sealer? pavetim Body - Exterior 3 10-01-2009 08:20 AM
seam sealer turbo t Body - Exterior 3 07-11-2009 11:58 AM
Epoxy sealer/seam sealer/paint equip Blackdog Body - Exterior 17 10-21-2004 11:19 PM
Seam Sealer nova33 Interior 3 04-20-2004 02:16 PM
