2008 5.3 - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-13-2019, 06:09 PM
2008 5.3
what they call a 2008 5.3 engine ls1 or what
vin is m and it is LH6
thanks
Old 08-13-2019, 06:30 PM
39 master's Avatar
All of the gen III & gen IV are collectively called LS1 or LSX but the actual engine may be an Lq9, Lm4 or whatever. It could also be a 4.8, 5.3, 5.7, 6.0...etc. Best way to tell exactly what you have is to get the VIN from the donor vehicle and look it up.
Old 08-13-2019, 06:42 PM
LATECH's Avatar
Last journal entry: GTO Reproduction Hood
https://www.southernperformancesyste...k-casting.html
Fact is stranger than Fiction
Old 08-13-2019, 06:54 PM
thanks it is a 5.3 and a aluminum block I knew that much all ready that chart still did not say what it was
Old 08-14-2019, 11:00 AM
123pugsy's Avatar
Rod...from a Chrysler?
Last wiki edit: Metal shaping
Last journal entry: SEAM SEALER
Wiki Edits: 29
They are called "LS based, LS family", but they are not LS.
The truck engines are called Vortecs. (not sure about the newer ones)
The LH6 is called exactly that, an LH6
https://help.summitracing.com/app/an...6-engine-specs
Old 08-14-2019, 11:37 AM
So it is the same as ls1 and ls6 I was told for the intake
Old 08-14-2019, 05:17 PM
39 master's Avatar
LS engines
Here is a picture of my '39 with the LSX logo.
So, exactly what is your question? I guess I missed something. Are you asking about interchanging intakes?
Old 08-14-2019, 06:05 PM
123pugsy's Avatar
Wiki Edits: 29
It's not an LS motor, it's a truck motor. Intake manifold and accessories will be different.
Oil pan as well.
Old 08-14-2019, 07:06 PM
39 master's Avatar
Parts are different but MOST will interchange such as oil pan, intake and water pump. Heads on early LSX and late LSX have different intake shaped ports, care must be taken to match the type of port to the intake when swapping.
Old 08-14-2019, 07:37 PM
I need to find a shorter intake someone told me that a ls1 or ls6 will work on it
Old 08-14-2019, 07:38 PM
I'm just getting the motor not in anything just sitting on a shelf
Old 08-14-2019, 10:36 PM
39 master's Avatar
OK, the LH6 is a replacement for the LM4 which is also an aluminum block. According to my research the LH6 is a cathedral port head so the "LS1" style 5.7 intake will fit. Search around and you should be able to find an intake for under $200. The oil pan can be replaced by many other shorter pans. Again, research and you should find what you are looking for. Go with the stock GM parts because they are cheaper.
The Following User Says Thank You to 39 master For This Useful Post:
123pugsy (08-15-2019)
