'27 Tcoupe - Hot Rod Forum : Hotrodders Bulletin Board
Hot Rod Forum : Hotrodders Bulletin Board > General Discussion> Projects/Builds/My Ride
Old 01-19-2015, 08:00 PM
'27 Tcoupe
Well, I am building a '27 T Coupe. I bought the body about 15 years ago. I have been collecting parts for it lately, and finally started to work on it. It's going to be full fenders and running boards. and be a big tire car (pro-street).
I got a 9" rearend, which I have removed the brackets, kinda cleaned the the housing up. I'm going to shorten the housing to 41 1/2 inches.
I have a Model A axle that I was going to drop it myself, but decided to just buy one. Not a new one, but a Henry axle thats been dropped. I am going to keep the radius nar not split.
I have everything for a 4spd, but with my knee getting wrost, I am going to go with a 700r instead.
I have welded up most of the frame, and I have the body mostly fitted to it. I am working on the rear part of it, to hold the back of the body firm. I will be removing the wheel wells to tub it. which will remove the rear sub-frame which holds everything in it place. The wheel wells will be about 21" apart.
I have done alot of things to the body which doesn't show. I changed the cowl, which turned out to be a can of worms. Everyone say's a '26 is the same as a '27. Not true. It's a '26 and a improved metal '27. A improved '27 does not have wood around the windows, and the dash does not bolt to the cowl, it bolts to brackets riveted to the "A" pillars, and a bunch other things your probably not interested in.
I will post some pictures tomorrow. Heres a couplke for now,
Pat
Name:	Coupe body (Small).JPG
ID:	198137   Click image for larger version
Name:	other side of body (Small).JPG
ID:	198145   Click image for larger version
Name:	fitting replcement cowl (Small).JPG
Old 01-20-2015, 09:57 AM
454 Rattler's Avatar
NEVER SATISFIED !!
Keep the pictures coming. This looks like another nice project. Not too many of these around here.
454 RATTLER
Old 01-20-2015, 03:58 PM
delawarebill's Avatar
oh boy a T with leg room
wonder what's that's like ??? keep the pic's coming..
Old 01-21-2015, 11:16 AM
DERPR30's Avatar
27 t coupe
Good luck with your t u might like mine
Old 01-21-2015, 12:49 PM
I've been doing some more work on it. Most is fixing things so that I can do another thing. Monday I spent backing up on what I did. I had removed the rear sub-frame cross member, and then cut the corners of the side sub-frame off. So that I could build a framing to support the rear of the quarters, when I remove the wheel wells.I welded a brace across the the trunk opening and removed the rear lower panel, and bracing. I made a new rear sub-frame cross brace. When I went to fit it. it was a inch to short. I forgot to weld a brace on the bottom sub-frame sides and with all the work I did getting everything out, it had spread it's self. No problem, except who owned it before me did some real doggy body work. I removed up to 3/4" of bondo from the wheel wells, and both quarter corners. I couldn't find what was square to anything, and what actually had moved! But all is good now.
I tacked welded the rear kick up part of the frame in place, and of course my welder started to act up, and it was working great just before that. I still need to pick up some more metal to make the forward frame bracing to take any flex the rear part tries to make. And some for the tranny mount.
Pat
Name:	Building the Pro street frame (Small).JPG
ID:	198378   Click image for larger version
Name:	Copy of PB300003 (Small).JPG
ID:	198386   Click image for larger version
Name:	welding never ends (Small).JPG
ID:	198394   Click image for larger version
Name:	had to remove home made crappy rear panel. (Small).JPG
ID:	198402   Click image for larger version
Name:	removed bondo that someone put on, over brazed on plate over old metal bottom. Crap work (Small).JPG
Old 01-21-2015, 01:08 PM
I had picked up a Model A axle . I am keeping the wish bone, and I am going to use the Model A spindles. My brother is making me up the bushings to hold the rotors on, in the right place.
I went to a local yard and pulled the brake/clutch pedals, and the steering sector/column from a Ford F1. $50.00 and he held the truck in the air with a big front loader for me, while I pulled the parts.
I am going with drag link steering, not cross steering.
I like to make everything I can. I have never liked going and buying the parts I can make. I was a Investment mold maker for over 35 years, and have always machined anything I could. I've always had a Bridgeport, and a lathe. I can't believe I didn't bring a mill & lathe, when I move from Mn to Tn.
More later.
Pat
Name:	Model A axle for coupe (Small).jpg
ID:	198442   Click image for larger version
Name:	'50 Ford F1 brake & clutch pedals, for coupe (Small).JPG
ID:	198450   Click image for larger version
Name:	'50 Ford F1 steering sector for coupe (Small).jpg
Old 01-21-2015, 09:34 PM
Cape Cod Bob's Avatar
Last wiki edit: How to title a hot rod
Keep on it, a build I would like to do.
Old 01-30-2015, 06:23 AM
Well I was able to get some things done, while waiting for my new lower rear panel to get here. I have no heat yet, but should have a ceiling in this spring, so that I can heat it. Of coarse, I was suppose to have it in last fall! Crap happens!
I built a new rear frame support. which will hold the rear of the body & the bottom of the rear panel. I will be cutting the rear side sub-framing out, with the wheel wells. I bent up some 1" tubing into a 34" dia, to get two tubes to go around the wheel wells, to help keep the rear of the body in place. There's not much left after I cut it all out, and I don't want it to more around.
I got up in place and the rear body bolts in and everything tacked in. I will add the fish plates to the sides of the frame when I do the final welding, with the body off.
I put the cowl, header plate, and dash back on. I used electrolysis to remove the surface rust that was on it. Worked good, I did a bunch stuff. Until I was out working and a rain storm came up out of nowhere, and fried my charger while I was watching it down pouring, and then Boom, lighting, and my charger went buzzzzzzz-pop! and never worked again!
Now I'm going to use feed molasses, once it gets warmer out.
I changed my cowl, and in doing so, I had to remove the dash mounts from the donnor parts I have. I had to drill out the rivets that hold them to the old "A" pillars, and remove the ones on my car, so that I could mount the dash again. the mounts also hold the middle door hinge. Now I have to get some flathead pop rivets to mount them in. sand them flush with a dab of mud, and they will look like regular rivets. I made a little tool to center drill the rivert in the trunk, and I am drilling 9 (I think) round headed rivets on each side, that hold the rain guttters in the trunk. Henry riveted everything together! Removing rivets suck! People say to me, why don't you just drill the head off, and pop them out. Anyone that thinks rivets come out like that, have only removed pop rivets. I need to change the gutters because the ends are gone, and I have the replacement ones already.
I will have to run to town, and get my steel soon. Town is 45 miles from us. Our town has nothing!!! One stop sign. no food, no gas, no police/sheriff, nothing, just a part time post office. We have to drive 25 miles to get anything, but we like it that way.
pat
Name:	PC260036 (Small).JPG
ID:	200770   Click image for larger version
Name:	P1280053 (Small).JPG
ID:	200778   Click image for larger version
Name:	P1280054 (Small).JPG
ID:	200786   Click image for larger version
Name:	P1280055 (Small).JPG
ID:	200794   Click image for larger version
Name:	P1280056 (Small).JPG
Old 01-30-2015, 06:34 AM
A couple more piictures
Pat
Name:	P1280057 (Small).JPG
ID:	200818   Click image for larger version
Name:	P1280059 (Small).JPG
ID:	200826   Click image for larger version
Name:	P1010002a (Small).JPG
ID:	200834   Click image for larger version
Name:	P1010004a (Small).JPG
ID:	200842   Click image for larger version
Name:	Before I removed the rear sub-framing..JPG
Old 01-30-2015, 06:50 AM
Last wiki edit: General Motors transmissions
Wiki Edits: 27
front brakes
I think the wheel bearing spacer used to put 40's juice brakes on an A axle will work for the disc conversion. I haven't decided on what axle - brakes I will use when I finally get around to my A roadster.
Old 01-30-2015, 03:08 PM
I do like your T Coupe. I had a electronic Hilborn with 15" stacks for mine, but I sold that motor, and am going with a sbc 350 in mine. I was looking at a 6x1's for mine, but a neighbor told me his friend needs money, and wants to sell his 3x2's cheap, so........I'm waiting to hear about it.
Pat
Old 01-30-2015, 03:17 PM
I have looked and asked around, and as far as I can find, they don't make a spacer for a "A" spindle, only for '37-'48 spindles. Which has a shoulder on it, holding the bearing out farther. The "A" spindle needs 7/16 spacer to move it out to be right for the rotor, to sit in the right place for the caliper to work. But then the seal might ride on the seam between them. So I'm just having my brother make them for me.
But Hey, Thanks for telling me. I can always use info.
Pat
Old 01-30-2015, 08:49 PM
Very cool build, I have always liked those bodies, keep up the good work.
Old 02-10-2015, 12:02 PM
I finally got the new rear panel. I have removed everything on the back of the body including the rear window panel. I went to fit the brace for the top of the rear panel, and it was 5/8" to short, What! I did some checking and asking around, to find out the guy that owned the car had cut the ends off, and welded them on. Why, I don't know. I have cracked them, yes they weren't welded very good. I took them off, cleaned them up and welded them back on with a 1/4 spacer on each end, and now it fits right. I need to de-rust some parts, and replace the corners before reassembling it all again. I guess I need to go and get some molasses, to do that, and the order replacement quarter corners. I just made 8 welding butt weld clamps, for the body patch panels I need to weld on. The passengers side is toast, he did some dog crap brazing on it, and it now has to go, he screwed up both sides. Idiot.
I have done some other interior body stuff also. I also removed all the hinges from the doors. Someone had done some light welding on the door by one hinge, and welded two of the screws to the body, and the slot shut. It took awhile, but I was able to get them out. You can't leave any of the screw in the hinge, because it won't slid out of the slot.
I was looking at the dash, and decided to get a different one, so that is on my to get list.
Pat
Name:	P2070025 (Small).JPG
ID:	203777   Click image for larger version
Name:	P2070024 (Small).JPG
ID:	203785   Click image for larger version
Name:	P2090042 (Small).JPG
ID:	203793   Click image for larger version
Name:	P2090043 (Small).JPG
ID:	203801   Click image for larger version
Name:	P2090045 (Small).JPG
Old 02-10-2015, 01:08 PM
techinspector1's Avatar
Last wiki edit: DynoSim combinations
Wiki Edits: 326
That's a little cutie pie.
