2k Primer reacting - Hot Rod Forum : Hotrodders Bulletin Board
Hot Rod Forum : Hotrodders Bulletin Board > Tech Help> Body - Exterior> Paint
Old 09-17-2018, 12:02 AM
2k Primer reacting
Hi!
My 2K primer is reacting in some places.
I did add 5% thinners, could that be the culrpit? I've never seen 2K primer react before with previous paint. Previous paint is atleast 15 years old.
Thanks!
Old 09-17-2018, 10:43 AM
The previous paint is more then likely some kind of un-catalyzed product, lacquer or enamel of some sort and the solvents in the 2k are biting into it. What you have to be careful of is even if the 2k goes down ok the solvents can still penetrate that layer and make it soft or gooey in the middle of it all and lead to durability issues.
Old 09-17-2018, 11:23 AM
The very first place something like that will do this is where the substrate was sanded thin. The solvents from the primer are soaking through it and lifting it from what it was applied to.
The best trick is to sand it out, then apply primer drier so that the solvents flash off before they can soak through.
The Following User Says Thank You to MARTINSR For This Useful Post:
John long (09-17-2018)
Old 09-17-2018, 11:46 AM
idrivejunk's Avatar
Grand Prix User
Last journal entry: Last look
Yep, solvent penetration of a sensitive substrate. Adding thinner did not help. Be sure to sand off all the loose stuff until it featheredges nicely.
Old 11-16-2018, 12:39 AM
Originally Posted by idrivejunk View Post
Yep, solvent penetration of a sensitive substrate. Adding thinner did not help. Be sure to sand off all the loose stuff until https://touchscreenwifirouter.com featheredges nicely.
Great advice!
SPI 2k Primer, or High Build primer? JohnnyK81 Body - Exterior 24 03-08-2011 07:25 PM
Epoxy Primer & 2K Urethane Primer acquadigio79 Body - Exterior 17 08-15-2009 04:07 PM
Epoxy Sealer-Primer With 2K Build Primer on top kilgorq Body - Exterior 4 04-29-2008 04:30 PM
Fresh Base reacting with old base on spot repair myfamiliacc Body - Exterior 11 03-20-2005 08:07 PM
