2k urethane primer over etching primer - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-05-2014, 07:05 PM
Hi to all , need some help in here
Can i use 2 k urethane primer over etching primer??
Thank you for your time
Old 05-05-2014, 07:17 PM
What you need before you use any product is the Tech sheet for that product. I googled "Nason 421-19" and this was at the top of the search.
http://www.pc.dupont.com/dpc/en/US/h...-17_421-19.pdf
You can print it out and follow it, it has all the info you will need to use it. And yes, the etch primer is one of the "suitable substrates" for your Urethane primer.
Properly treated bare fiberglass, steel and aluminum as well as thoroughly sanded, painted surfaces.
Treat bare metal areas with Nason® 491-17TM Etch Primer. 491-16TM Ful-PoxyTM Epoxy Primer or other Nason® Etch Primer or Epoxy Primer.
The Following 2 Users Say Thank You to MARTINSR For This Useful Post:
ciccio0185 (05-05-2014), MecGen (05-08-2014)
Epoxy Primer or Etching Primer ? ? ? SCHOONER Hotrodding Basics 3 03-01-2010 08:18 AM
Self Etching primer vs. epoxy primer elcaminodragster Body - Exterior 47 06-08-2009 08:17 PM
can i spray epoxy primer over etching primer without sanding? wickiewicked240z Body - Exterior 1 08-29-2006 10:07 PM
Epoxy Primer / Etching Primer olds37dude Body - Exterior 3 01-27-2005 05:25 PM
Do you need etching primer under featherfill primer? Fordy8man Body - Exterior 14 10-29-2003 08:23 PM
