33 Ford replacement panel for fuel tank? - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-27-2019, 09:43 AM
31ROC's Avatar
Not liking the fuel tanks that hang out the rear, I'm replacing mine with a cell in the trunk. I attached pics of lower panel removed, exposing tank for removal.
Is there such thing of a replacement panel to finish off the rear without the fuel tank and existing panel?
ID:	450781   Click image for larger version
ID:	450783   Click image for larger version
Old 12-27-2019, 03:40 PM
If you massaged that fuel tank a good amount with a body hammer or a welder/ cutter to add a angle /remove that corner sticking out you might be able to fit a stock panel over it then modify that for a filler neck giving a stock look.
Or if possible move the tank forward and add more angle to the filler neck.
Old 12-27-2019, 03:58 PM
idrivejunk's Avatar
Grand Prix User
Last journal entry: Last look
This is a car I worked on that already had this panel on it.
But I see theres a gas cap there. I bet different styles are available. That one is steel and needed brackets connecting bumper to frame. Anyway, I don't know what its called or where it came from... but would it be what you are looking for? Try the search terms "33 Ford gas tank cover" or "33 Ford roll pan". I found this:
1933-34 Ford Gas Tank Cover
The Following User Says Thank You to idrivejunk For This Useful Post:
31ROC (12-28-2019)
