350 build questions - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-25-2014, 11:17 PM
350 build questions
Hey all
I'm a newbie. Trying to learn. Love the site so I joined.
Here it is:
I have a early 70s 350 4 bolt that I am working with. Nit will be going into a 1963 ss impala
I am going to put flat top 4 relief pistons in it
I restored and cleaned up some 461s for it
I have a 286 fireball cam I want to put into it. will it work? 9:3 - 1 compression
cam specs
286/292
213/220 @050
434/450
110 lsa
Don't need a race motor just a nice engine for a muncie 4 speed.
also what size holley? 600 or 750 dp
I have all ofthese parts Iis why I am asking. Any help would be great!
Thanks!!!
Old 12-25-2014, 11:22 PM
johnsongrass1's Avatar
Race it, Don't rice it!
It's a bit old in technology but it will work.
Old 12-25-2014, 11:38 PM
Thanks for the reply
any idea for hp or carb? I'mthinking the 600 holley dp.
Old 12-26-2014, 12:39 AM
vinniekq2's Avatar
normally I would say the 750 carb.Because its not making a tonne of power the 600 should be fine.low 300s for hp?
Old 12-26-2014, 08:39 AM
Thanks Vinniekg2 for the help
Old 12-26-2014, 04:35 PM
techinspector1's Avatar
Last wiki edit: DynoSim combinations
Wiki Edits: 326
8.38:1 dynamic compression ratio on the KB calculator. Should work fine, but don't expect too much from the heads.
Old 12-26-2014, 07:04 PM
I ported the heads - smoothed out the rough areas and polished the exhaust. 1.94 intakes and 1.50 exhausts. Should be better then the 624 that were on it before. I calculated 9.3 to 1 .025 deck, .040 gasket, 64 cc chambers, 3.48 stroke, 4.00 cylinder, 7 cc valve reliefs. Am I wrong here? Shorty headers and a rpm performer intake. Trying to get to 350 hp. I should be close. What am Iinot seeing? I like to learn about this and am trying to understand not just slap parts together.
My new hobby - I'm a 50 year old kid! I have a good 327 also. Should I build that Iinstead. Just thought I could get 1 hp cubic inch easier with a 350. What are you thoughts anyone? Thanks!
Old 12-26-2014, 07:06 PM
Would a xe 262 comp cam work better here?
Old 12-26-2014, 09:58 PM
considering the weight of a '63 Impala I'd stick with the first choice and use a 1.6 rocker if your head can accept the lift.
Old 12-27-2014, 01:53 AM
TroyBoy's Avatar
Psychomotors
Sounds like a fun lil engine. I personally would go for a 600 vac sec and not a dp.
Old 12-27-2014, 05:36 AM
BuzzLOL's Avatar
Cars, Trucks, Boats
. With your .025 deck, I'd go .015" thick head gasket for .040" clearance/squish to improve engine quench effects and power and MPG... prolly 325-350 HP, maybe more, depending what you did to the heads...
. 'Z28' spec. valve springs of about 90-110 lbs. seat pressure and 250-280 lbs. open pressure at .450" lift...
What Is The Ideal Quench Height? - Hot Rod Magazine
chevy 350 build questions 73gremlin Engine 25 02-10-2014 11:31 AM
350 build up questions Bratzler Hotrodding Basics 24 07-25-2013 07:46 AM
350 build questions, looking for 300-350 hp Jaiden2010 Engine 18 06-23-2011 07:49 AM
350 build questions belly_up Engine 9 02-13-2009 06:23 PM
sbc 350 build up questions b/w72 Engine 9 01-08-2004 05:12 PM
