350 chev block - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-15-2012, 09:09 AM
350 chev block
trying to find out what i would have to do to build a 4 bolt 350/1978 /to get 300 hp/with set of 202 heads/block will be bored 030 over/for my 23 t roadster/this must be able to run on pump gas
Old 01-15-2012, 09:38 AM
BOBCRMAN@aol.com's Avatar
Using mostly stock factory parts. Easily build 300 hp engine.. Offered as stock in late sixties early seventies.. add modern aftermkt camshaft/intake/carb/ignition..
"T" bucket won't need much.. A 350 horse cam, Performer intake, 600 Holley and you got a white knuckle ride..
My bucket has a 383, .480 lift cam, 750 carb, 144 supercharger. It'll keep ya busy at full throttle with the 15" wide Sportsmans giving off a blue/white haze!!
All I hear is "Crazy old Bastard!!!!" slow this thing down..
Old 01-15-2012, 10:26 AM
zildjian4life218's Avatar
Listen and Learn
Last wiki edit: DIY junkyard electrical fan controller
Last journal entry: SBC 305 Twin Turbo
Wiki Edits: 7
This will be a very easy build. I wouldn't stress a 4 bolt in your application. Its wasted for someone that needs those extra bolts and is willing to probably buy it off of you for more than you can get a 2 bolt and a gasket set for.
If you could start off with a parts list of what you have already and we can figure out what you still need. If I were you I would go buy a late 90s vortec L31 engine and convert it to carb and be done. Great heads and roller cam from the factory. That should easily make 300hp. Just a thought...
chev big block in a 53 studebaker joes stude Engine 7 07-02-2013 02:45 AM
350 chev block jim gemmrig Introduce Yourself 4 01-18-2012 11:42 AM
Big block chev id? marv119 Engine 2 08-19-2007 08:51 PM
Big Block for 55 chev car walkerbodyshop Engine 8 07-30-2006 04:56 PM
Installing a chev small block in the rear of an chev s-10 vegadeth Body - Exterior 11 07-16-2002 03:16 PM
