36 ford installed side engine cover - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-22-2018, 08:05 AM
Hey guys is there a kit if you want to eliminate the side engine covers and just put the hood on alone?
or do you just attach it to the grille and rear by the cowl?
ID:	426665   Click image for larger version
ID:	426673   Click image for larger version
Old 05-22-2018, 08:43 AM
35WINDOW's Avatar
Last journal entry: Update on my Build-Lights
Don't you have already have inner Fenders (that the Hood registers to)? I don't completely understand your question-
Old 05-22-2018, 11:35 PM
I want to remove the side engine covers so it shows the engine
Old 05-23-2018, 06:43 AM
35WINDOW's Avatar
There are more than a few choices to do so-
You can use your Hood Tops as they are,and take the lowers off-
Or,you can buy an one piece Hood (from someone like Rootlieb), and either lift it off (if needed), or put a forward tilting option on it:
http://nebula.wsimg.com/152de12950cd...&alloworigin=1
FAST FORWARD HOOD HINGE INSTALLATION
Or, as you already have the Radiator support rods (there are options here as well), you can run without a Hood completely (as I am doing)-your imagination is your only limit-
The Following User Says Thank You to 35WINDOW For This Useful Post:
johnnyford123 (05-23-2018)
Old 05-23-2018, 07:27 AM
454 Rattler's Avatar
NEVER SATISFIED !!
I installed sliding pins in both sides of the hood. When you remove the side panels there is a channel in the hood top. That's where the pins go. Then I drilled holes in the cowl and installed grommets to slide the pins into.
It worked great for me.
454 RATTLER
The Following User Says Thank You to 454 Rattler For This Useful Post:
Old 05-23-2018, 07:36 AM
YES I want to remove mine and somehow fasten my hood to the rad area and cowl.
Thanks
Old 05-23-2018, 08:28 AM
35WINDOW's Avatar
Again, more than a few ways to do this-my favorite:
https://www.honestcharley.com/vintag...stainless.html
Or, there are single and triple latching Hood opening kits:
3336 Triple Opening Hood Hinge System
You can also use quicklatches:
https://www.speedwaymotors.com/Quik-...CABEgJy5fD_BwE
As 454 Rattler has mentioned there are some great home brewed Hood latch ideas (that are virtually hidden)-again, your choices are only limited by your imagination-
Thrust button stopping timing cover being installed v8hed Engine 21 08-04-2018 07:16 PM
picked up a 4-speed muncie 63-65/. side cover info bsa_bob2 Transmission - Rearend 2 06-11-2014 07:25 AM
Loud tapping noise under driver side valve cover Chevyman87 Engine 4 12-10-2012 10:08 AM
over heating = 454 in 37 Ford fan in front of radiator, no room on engine side. art37 Engine 9 10-23-2011 08:15 AM
Tming Cover Gasket - Which side? Best Practices? dhunt00c Engine 4 08-19-2008 07:14 PM
