366 Tall Block Stock Hp - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-13-2009, 02:42 PM
How Much Hp Is In A 366 Tall Block And What Will It Rev To. I Want To Install It In My 67 Chevelle Ss Just For Looks And Dependability. What Do All Of You Think?????
Old 03-13-2009, 02:55 PM
richard stewart 3rd's Avatar
Last journal entry: 351W rebuild
Hi,
Look for a different engine, I had a three car carrier with one of these engines in it, it has a lot of torque, won't rev very high &
used way to much gas, it is a truck engine.
Rich
Old 03-13-2009, 06:55 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Take a good look at the pistons that come in this engine. You'll understand why it's a tall block.
Hold out for a 396 or better still a 454 is my opinion.
Old 03-15-2009, 02:32 AM
DoubleVision's Avatar
Don`t waste your time on a 366. As said these engines are work truck engines and don`t make any horsepower as they are designed to make torque. Since the deck is taller and the heads sit up higher you won`t find a set of headers that will fit unless they are custom made. These engines use the classic formula for a torque engine, long stroke, small choked up bore.
Old 03-15-2009, 08:13 AM
BOBCRMAN@aol.com's Avatar
When I get a 366 in. I remove the main caps, pull the crank and rods. Trash the remainder.
The main caps are used to convert two bolt blocks. The crank is steel and can be used in any 3.76 based build. The rods make good street/mild race rods with a bolt change and size job.
Old 12-07-2009, 11:05 PM
58lincoln's Avatar
Last journal entry: New (used) 350.
haha, looks kinda cool here tho http://www.youtube.com/watch?v=YS8la...om=PL&index=10 http://www.youtube.com/watch?v=890-W_BJSIk
stock Big Block Manifold ??? Augusto Engine 9 11-07-2007 08:33 PM
Stock 2-bolt 400 block with splayed caps Mad Maggot Engine 25 10-31-2005 07:32 PM
what is a tall deck block? bigwildgrin Engine 3 06-04-2005 04:58 PM
To block-fill 400 or not? firechicken383 Engine 33 04-28-2005 03:00 PM
