383 build - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-01-2014, 10:48 AM
383 build
So the other day I picked up a locked up 69 350 sbc for 35 bucks. I pulled everything out and the cylinders have just a little rust, haven't been previously bored or anything, but i think it's a good block to make a sweet build with. Of course ill have it cleaned up at the machine shop.
My plans are to stroke it to a 383 for sure,
I would appreciate recomendations for cam, heads(maybe vortecs), intake manifold and a carburetor. And a recommendation for what crankshaft I should use.
Im probably gonna put it in a truck. Im looking for some good torque and horsepower, but for the street. Enough that I can show those 5 liters whose boss
Old 03-01-2014, 11:04 AM
clwhoops44's Avatar
buy a complete rotating assembly. crank, rods, pistons, rings, balancer, flexplate/flywheel, bearings, all fully balanced for under a grand on skip white performance. trust me, it will save huge amounts of time and money to buy it complete, plus all the parts are going to be much stronger than any stock stuff. listed as good to 500 hp.
you can shop around, but i did for months, and that was the best deal i found. (balancing alone is ~250 bucks here in charleston, wv)
for the heads, if you find a screaming deal then go with the vortecs. if not, id go with an aftermarket aluminum head. plenty to choose from for under 6-700 assembled.
eddy performer rpm intake, definitely. DO NOT BE TEMPTED TO GO SINGLE PLANE
750 carb, i prefer holley
build more for torque than hp, maybe 9:1, 9.5:1 compression with a 210-220ish duration cam. i think the vortecs have to be machined to accept more than .450 ish lift??
ill let people with more experience nail down a cam recommendation.
Old 03-01-2014, 12:14 PM
The mobile view is crap
A good block to start with would be a 1 pc rear main factory roller block. Vortecs are a nice factory head but require some work to get more than around .470 lift or so.
Read through these links for good vortec info http://www.crankshaftcoalition.com/w..._cylinder_head
Vortec Cylinder Heads: The Definitive Guide - NastyZ28.com
Use Google to search for 383 builds. There are so many out there you could not read them all in your lifetime.
Old 03-01-2014, 12:31 PM
vinniekq2's Avatar
1) choose the power you want
2) find the right heads for that application
3)decide what{roller cam preferred} cam allows the heads to flow their potential
4) match compression ratio for cam and fuel used
Balance the engine parts
Old 03-01-2014, 12:43 PM
techinspector1's Avatar
Last wiki edit: DynoSim combinations
Wiki Edits: 326
L31 heads are excellent on a mild 9.5:1 street 355, but when cubic inches are bigger, you need to go with bigger heads, unless you want to build a low-rpm torque motor. Then the L31's will work great, but you're still limited to 9.5:1 SCR because the heads are iron. Aluminum heads will support up to 10.5:1 SCR. More SCR supports more cam.
Old 03-01-2014, 06:57 PM
Thanks for the replys, im probably going to go with some type of kit, but im not sure which one
Old 03-02-2014, 03:40 AM
I am using a 4340 scat crank and a voodoo 60121 cam...Vortec heads.
Old 03-03-2014, 06:49 AM
Last journal entry: Still running strong
Camaro Performer magazine had a write up on 383 build for 3000.00. I think its in the March issue.
350, 383, build, fast
whats better 400 crank or a 383 crank in a 350 sbc when trying to build a 383? onlychevy Hotrodding Basics 14 12-28-2012 07:27 AM
383 build ithooks Engine 5 12-16-2012 09:14 PM
383 build DragonsBane Engine 5 07-02-2007 04:16 PM
383 build up 427COPO Engine 2 11-27-2006 07:17 PM
383 build tom penicaro Engine 1 02-24-2006 03:17 PM
