383 Horse Power? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-17-2014, 08:57 AM
Last journal entry: 1979 Camaro Berlinetta
383 Horse Power?
I have a 383 stroker and wondering what the power would be. from top to bottom. Holley 750, edelbrock performer eps intake, the corvette 882 heads with the large valves and port and polished and machined to I think 72cc chambers, the thinnest head gasket I think its .015, Bored 30 over with forged flat top pistons, summit K1103 cam, machined deck, forged rods and a 400 crank with the press on pully not bolt on. its a 1968-1970 4 bolt main. Thanks
Old 09-17-2014, 08:59 AM
vinniekq2's Avatar
370 maybe more?
882 heads?
Old 09-17-2014, 09:29 AM
Never seen a 400 crank that used a press on only balancer (I assume you mean balancer) I believe all Chevy cranks starting around 1959-60 had a retaining bolt. Are you sure you have what you think you have?
Old 09-17-2014, 10:26 AM
Yeah its the harmonic balancer in press on not bolted on.
the heads are 333882.
Old 09-17-2014, 10:34 AM
vinniekq2's Avatar
only pressed on balancer I remember is the old 283s and older.
Like fbird says,give those heads to someone you dont like
Old 09-17-2014, 07:27 PM
Proud LOSER
Good old "corvette" 882 heads.... your dcr is likely way high given the smallish cam and 10.5+ scr, the heads are junk, i think Vinnie is going to be on the money at 370 and even that might be optimistic. Swap some real heads on it, stay 72cc chambers, will make 400+ even with the smallish cam.
Old 09-17-2014, 07:34 PM
ericnova72's Avatar
More for Less Racer
How much was the block deck machined?? If it was more than .010" you have a potential problem with using the .015" thick head gasket...the pistons will hit the heads at rpm because you are too close on piston to head clearance.
With forged pistons, .035" total piston the head is a minimum safe spec, below that you risk a collision.
Old 09-17-2014, 07:52 PM
Proud LOSER
This Eric, I missed that completely lol...
Old 09-18-2014, 09:40 AM
It has flat tops with valve reliefs. I how the pistons don't hit because I had this car up to 9000rpm. The deck height I have no idea how much was taken off. I was looking at the summit vortec heads at 64-72cc but I don't want to have to get a new intake (vortec style) because I just bought a new intake. Can someone recommend me some heads or wants to sell me some or know where I can get some for cheap? Thanks
Old 09-18-2014, 09:48 AM
vinniekq2's Avatar
If this engine went to 9000 rpm,you have all the right pieces
Old 09-18-2014, 10:05 AM
Yeah I go to a high performance school (UNOH) had my teacher port and polish and machine the 882 heads. Flow checked them and they flow the same as dart iron eagle heads. Don't get me wrong they do suck and are heavy that's why I wanted to get aluminum heads.
Old 09-18-2014, 11:42 AM
Proud LOSER
9000 rpm stock block and stock 400 crank
882 heads that flow with a set of Dart iron eagles...
Cool thread...
The Following 2 Users Say Thank You to bygddy For This Useful Post:
AutoGear (09-22-2014), clwhoops44 (09-19-2014)
Old 09-18-2014, 11:44 AM
vinniekq2's Avatar
Dave,I wonder what ICS thinks?
Old 09-18-2014, 12:02 PM
Proud LOSER
That it had better have a windage tray? Lol
383, cam, holley, power, stroker
First 383 stroker how much horse power and any advice on what to change Mr. Mars Hotrodding Basics 10 06-11-2012 11:28 AM
383 build horse power cam? peteall70chevy Engine 0 02-23-2011 12:10 PM
horse power bad2be Engine 5 07-19-2006 09:45 AM
horse power bad2be Engine 3 07-11-2006 11:09 PM
How much Horse power will i get DragBoy4ever Engine 3 02-08-2006 02:01 PM
