383 stroker build - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-24-2009, 07:35 AM
383 stroker build
this motor is getting built 4 me while im on vacation!
Engine: 383 stroker build
forged eagle crank internally balanced
forged eagle h-beam rods
forged SRP pistons
roller tip rocker arms (long slot)
high pressure(not volume)oil pump
edelbrock rpm performer heads (aluminum)
edelbrock rpm performer air gap intake(aluminum)
540 lift comp cam
rhoades lifters
edelbrock 750 carb w/electric choke.
Main and rod bearings
Camshaft bearings
Plasma moly rings
New arp main rod and head bolts
Probably more that im forgetting to list!
Transmission:
700r rebuilt with all new parts (beefed up)
has mild shift kit
2500 stall converter and new dip stick and speedo cable.
Rear end:
411 gears
all new seals, gaskets, bearings and shims. all parts are gm and new.
kfrom76
View Public Profile
Send a private message to kfrom76
Send email to kfrom76
Find More Posts by kfrom76
Add kfrom76 to Your Contacts
Old 11-29-2009, 05:46 PM
Is the 2500 stally large enough?
Hi, quick question.... What are your cam specs as your stally should really kick in atleast 500 rpm after the pwer starts to kick in.
Old 11-30-2009, 08:52 AM
sounds preet mean. maybe shoot some pics up when you see it being built?
Old 11-30-2009, 11:32 AM
my87Z's Avatar
Veteran/Firefighter-Paramedic
i agree, and with the .540 lift it should be at least 236+ duration @ .050, if so i would want more like a 32-3500 stall. other than that i really dont understand the post, as it doesn't have a question, so to the OP what is it that you need to know
Old 11-30-2009, 12:56 PM
Thats all
The question was, what are your cam specs as my thoughts were that since your cam has .540" lift you will need a stall of around 3000 rpm to which will generally flare to 3500 rpm. Using a smaller stall will literally dump power in your transmission, fix this and it sounds like you are on a neat combination.
Cheers, you answered my question.
Old 12-01-2009, 09:27 AM
my87Z's Avatar
i'm sorry, i didn't mean i dont understand your question PRO 347, i was only agreeing with your question, i think we were saying the same thing.
the original post really didn't have a question and i really couldn't understand what he wanted to know that was all, but since i did quote your post i can see how you would have taken it the wrong way
Old 12-01-2009, 10:56 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Me either- I think dude's giddy he's getting his deal together, is all!
Old 12-03-2009, 09:19 AM
my87Z's Avatar
i was too, i really haven't been on this site for a while, i used to get on while at work in the navy, great use of government money, but you can do that when your the supervisor and you make sure your stuff gets done right, but now i'm out, got my car together and thanx to all for the help
Marine 383 build mtnrat Engine 25 03-31-2014 06:47 PM
Speedfoos 383 Volvo Amazon Build speedfoos Hotrodders' Lounge 139 03-10-2011 09:37 AM
383 Stroker Build - Just looking for input ziatzev Engine 7 09-17-2009 08:00 PM
383 Stroker Project SandmanDr3am3r Hotrodding Basics 2 07-16-2009 12:52 PM
How do I build a 383 stroker? KFXrider88 Engine 1 06-11-2006 07:47 PM
