383 stroker clearance - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-05-2006, 04:37 PM
What do I watch for with clearance? I will be getting a stroker pan. How far can you clearance the pan rails before you hit water jackets? It is an 010 casting block. Rods are Scat I beam but are supposed to be for a stroker engine already. If I don't have a small base circle cam, will I still have to clearance the rod shoulders? It will be using a 3.75 stroke crank with 6.0" rods.
Old 10-05-2006, 05:58 PM
BOBCRMAN@aol.com's Avatar
There is no water close to pan rails. You may need to clearance the bottom of the cylinder bores. All you need is about .050 between parts. The aftermkt rods, in general, clear the camshaft as the bolt heads are further down on the rods big end base circle.
Old 10-06-2006, 10:06 AM
johnsongrass1's Avatar
Race it, Don't rice it!
I'm guessing your using the Eagle 6.0 rods? Capscrews?
They will hit the cam slightly on four and six depending on duration. Take off about 1/16 on the shoulder.
Old 10-09-2006, 08:07 AM
engine geek
The inside corners of the connecting rods may hit two or more cam lobes, depending on which rods and what cam. You have to grind on the bolt heads and rod sides to clear the cam. Sometimes you only have half of the head left. It looks terrible, but it doesn't seem to be a problem in service.
The bottoms of the cylinder bores usually need to be notched slightly
Sometimes the pan rail will need to be clearanced a bit, and I've had the counterweights on aftermarket cranks touch various spots in the block.
I use a foot-long zip tie that's about .051" thick as a test probe. I arbitrarily decided .051" was enough clearance.
http://www.bacomatic.org/~dw
http://autotech.freeforumhost.com/autotech.html
Old 10-09-2006, 10:57 AM
We have had many calls inreferance to getting into the water jackets when clearancing for strockers on the 010 blocks we cleance all our blocks in a CNC machine and on an old junk block we kept adjusting the program to go out further and further on the pan rails and on we found you have to becareful or you can hit water.
Just don't go any further then you need to as on some rods you don't need to go as far the bolts have smaller heads and are shorter.
Old 10-09-2006, 11:46 AM
I'm guilty of cutting out stuff to save weight(get it off hthe nose) but I've never hit water. I'd say it gotta be really deep.
Do you know how far you had to go to get to water?
383 Stroker question Houman SS '70 Engine 60 10-30-2009 08:46 AM
383 stroker kit (Ebay) Hazard Engine 8 05-24-2006 07:51 AM
Thanks for the 383 Stroker info Ron Mexico Introduce Yourself 2 01-11-2006 12:05 PM
I need your feedback Specs for my new 383 stroker ozzt Engine 12 01-11-2006 11:12 AM
383 Stroker clearance question draven Engine 16 12-06-2004 07:59 PM
