Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 383 Stroker clearance question
Old 12-06-2004, 05:54 PM
NXS's Avatar
NXS NXS is offline
wind & fire = guides to power
Be happy you've got the 6" rod pistons! You are well ahead using them in combination with a blower!(it will be less prone to detonation from timing or fuel problems...and that is what makes your engine self combust with a blower!) Be sure to run some cold plugs also, around an AC 42 or 43 temp range, depending on boost levels.
