383 stroker long block potential - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-29-2015, 05:16 PM
Hey all, I am interested in the 383 stroker long block listed in the classified adds here. It is said to be set up for a blower. What size and brand of blower and carbs would be best for that set up with the info given? also what trans and gears for a street rod, hot rod, muscle car. What kind of h.p. and torque could be expected? Or is this thing built for racing only? Thanks for all the info.
Old 03-30-2015, 11:04 AM
vinniekq2's Avatar
what does it have for parts?
Old 03-30-2015, 03:22 PM
The only info I know is what the add says. Just looking for knowledgeable opinions.
Old 03-30-2015, 03:29 PM
techinspector1's Avatar
Last wiki edit: DynoSim combinations
Wiki Edits: 326
Next time you are asking a question like this, at least copy and paste the ad so that we can see what you're talking about....
"Selling my short block or long block. Short block consists of 4 bolt roller 350 bored .030 over and clearance for 383 stroker ARP main studs scat crank eagle h-beam rods srp low compression forged pistons all balanced and blue printed, high volume oil pump, Milodon 7qt oil pan, custom grind hydraulic roller turbo cam by comp cams. $2500
If interested in the long block it has cometic 3 layer head gasket with ARP studs dart iron 200cc heads fully ported and polished with upgraded springs angle plug heads comp can pushrods and custom fabricated valve covers.$3000
Compression is at 8.5:1 so this setup can handle some boost. I have the receipts for everything including machine work
Located in virginia"
Old 03-31-2015, 01:53 AM
BuzzLOL's Avatar
Cars, Trucks, Boats
. I'd suggest discussing all this with the seller because there's a lot of detailed info missing from the brief ad... he may also be able to hook you up with all the parts to finish the build...
. It looks like it could make at least 450-500 HP...
15:1 383 stroker using 70s block thomjohn98 Hotrodding Basics 9 07-10-2012 08:38 AM
383 stroker kits?? for a 98 block kennyhammond Engine 7 01-18-2011 02:08 PM
where to get a quality 383 stroker kit ? (Long) Mustangsaly Engine 1 07-18-2006 06:13 PM
383 stroker block and cam ???????? mupton Engine 1 01-26-2006 09:50 PM
where to get a good 383 long block canter Engine 3 09-21-2005 10:53 AM
