Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 383 stroker low vacuum
Old 08-11-2016, 11:06 AM
StraubTech StraubTech is offline
Originally Posted by Roberto_Lux View Post
[COLOR=#000000]
[/COLOR]
Hi,
[COLOR=#000000]
[/COLOR]
Iíve bought 64 corvettes which has a 383 stroker engine. But Iím facing some problems when it comes to acceleration in "cruising mode" low rpm. I notice serious backfire, happening in the exhaust system and hesitations.
[COLOR=#000000] [/COLOR]Some initial data:
- Engine chevy 383 stroker
- Quick fuel carb Q Serie 750cfm Drag Race
- Aluminium heads
- MSD Distributor (Vacuum advance)
- Procomp ignition system (PC-2017_6AL & PC-2041D)
- CompCam Part # 12-433-8 (see attached cam card)
Here the tests I already did:
- Checked my camshaft and it matches the spec
- Set the ignition to:
total timing 34į BTDC and
initial timing 18į BTDC
- Compression test: all cylinders between 165 and 172 psi
- Spark plugs: all have black top ends (rich mixture) see pics
- Vacuum test: ONLY!! 5 inch Mercury (slightly vibrating between 4-6)
- Leak test on the intake: Couldnít find any leak. Even not with smoke ... it came out of the carburator top.
[COLOR=#000000]
[/COLOR]
Is my camshaft THAT SHARP, that such low vacuum can be expected?
Why are the plug showing a rich mixture when the vacuum test is indication a manifold leak, this should result in a lean mixture shouldn't it.?
[COLOR=#000000]
[/COLOR]
Iíll perform a second test where I will take of the carb and blind the connection flange, set the crankshaft to 45į BTDC (no overlap on any cylinder) so no smoke can go through the engine.
[COLOR=#000000] [/COLOR]Does anyone of you have some other ideas what I should look at?
Thanks
[COLOR=#000000]
[/COLOR]
Bob
[COLOR=#000000]
[/COLOR]
Anything ProComp or SpeedMaster should be thoroughly inspected and checked before being used.
The Following User Says Thank You to StraubTech For This Useful Post:
jokerZ71 (08-11-2016)
