390 fe with holley wont idle after driving hard - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-12-2019, 12:47 PM
Just after jetting up my 670 holley on my 390, I was driving it hard to see how it ran, and it ran great, then after coming to a stop, it barely idled anymore. Prior to it going bad, it idled with my msd box at 12 degrees at around 700rpm in park and it would drop to 500 in drive without ever dying. I checked for vacuum leaks, checked inside the dist, blew out the idle air bleeds, I even rebuilt some of the carb, blowing out the metering plates and replacing gaskets. After the rebuild, it ran better but still barely idled. the idle mixture screws don't seem to have an affect, but the carb idles normally if I put the choke on, but then it won't accelerate past Idle. It still cruises and accelerates normally and really good, no smoke from anywhere or any noises. Any Ideas with whats wrong? I figure its with the carb considering rebuilding it helped and it idles with the choke, but I already checked the air bleeds real good.
Old 07-12-2019, 12:59 PM
johnsongrass1's Avatar
Race it, Don't rice it!
Wrong metering or base plate gasket.
Old 07-12-2019, 02:39 PM
Just checked them, they both match
Old 07-12-2019, 03:29 PM
EragonSuperH's Avatar
I invent stupid usernames
Is it only after running it hard that it does this or is it constant now after running it hard once?
Sent from my VS996 using Tapatalk
Old 07-12-2019, 03:36 PM
i was doing a couple pulls back and forth down the street after changing the jets and it pulled good and idled fine after, then after one pull it started idling bad so I havent driven since, it's constant. I'm going to see if I can find a leak in the intake manifold to cylinder head seal, I think i've done everything I can with the carb
Old 07-12-2019, 04:08 PM
I checked one side of the intake and found nothing, I still have to check the other but I dont think I'll find anything. I'm at a loss for whats wrong, I've had to fix most of these things before and I've seen the symptoms, If it was an intake leak it would probably be eating oil and smoking, but its not. I'd think maybe something with the cam and timing chain, like if it skipped a tooth, but I took it out once with it running like this to see how it accelerated and off of Idle and just above cruising, it runs strong like normal. could the msd box be causing any issues? It's a digital 6A.
Old 07-12-2019, 05:52 PM
If it is advanced weight they could be sticky giving false readings and playing games with the idle speeds.
So will a leak around the throttle shaft bushings. If it’s bad enough the things gets hung up on the throttle blades and does dumb stuff.
Old 07-13-2019, 12:20 AM
So will a leak around the throttle shaft bushings. If itís bad enough the things gets hung up on the throttle blades and does dumb stuff.
I did check the advance weights, they were sticking but werent the problem. The throttle shafts could be something. I ended up going out and buying a 650 cfm edelbrock to keep my car moving. I runs really well now, I might not go back to the holley
Old 07-13-2019, 10:25 AM
Are you running a heat spacer between the Carb and the intake ? If not you probably should because the problem you described is common without one.
Old 07-16-2019, 07:47 PM
55_327's Avatar
Even with Holley float bowls exposed to air top and bottom? I've never experienced that problem, even on hot Texas days.
Edelbrock carbs are a different story. Their float bowls essentially sit right on the manifold. But the symptoms are lots of cranking required after a "hot soak" due to the gas boiling off on hot days.
Old 07-16-2019, 11:19 PM
Originally Posted by Simon Goodman View Post
....could the msd box be causing any issues? It's a digital 6A.
Good place to start these things are a frequent source of trouble.
Same for distributors which begs the question of what you are using?
Bogie
Old 07-17-2019, 08:01 AM
Last wiki edit: General Motors transmissions
Wiki Edits: 27
5.0 heat shield
Mustang early 80's 5.0 with the Holly 4 bbl used large aluminum sheet metal heat shield. bolt pattern should match.
390 fe, 390 wont idle, holley problems, holley wont idle, wont idle
