Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 4 to 3 wire taillights
Old 09-24-2013, 08:13 PM
OLNOLAN's Avatar
OLNOLAN OLNOLAN is offline
None of these cicuits make any sense because the turn signal wire and the brake light wire are the same. Brown is running lights on both sides, green is right turn signal and brake lights, yellow is left turn signal and brake lights, white is the ground. You're problem is a bad ground or trailer ball ground. Are you wiring brake, turn signals and running lights on a car or on a trailer please clarify.The way ya'll have it drawn up is a five wire circuit. 1)gound2)left turn3)right turn4)brake)5)running lights. Nolan
