Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 4 to 3 wire taillights
Old 09-24-2013, 11:03 PM
robin58 robin58 is offline
Olnolan, 4 bulbs. That's all I am trying to wire in. 1157 type. 4 wires going to them: brake, lt, rt, parking lights. Pl are irrelevant as obviously work. As stated above,I am simply looking for 4 lights on when braking, and each pair flashing when using turn signals. Without an adapter or relay in there, the lights obviously wouldn't flash with turn signals if the brakes were lit as they would still be getting 12v from the brake switch.
Fwiw, I've found this: Tail Light Mods 4 which appears to have used the exact same method I came up with but I still think Joe G's method should work too. I'll just wire it all up and see what happens...
