4.3L Vortec V6 powered FIAT 124 Spider - Hot Rod Forum : Hotrodders Bulletin Board
Hot Rod Forum : Hotrodders Bulletin Board > General Discussion> Projects/Builds/My Ride
Old 10-30-2014, 06:12 PM
v6spider's Avatar
My name is Rob and I am the Owner/builder of a custom carbureted Vortec V6 powered FIAT 124 Spider.
The engine features a comp cams 280 duration .525" lift hydraulic roller cam with retrofit hydraulic roller lifters and true roller rockers in an 85 block bored .030 over. The heads are Vortec fitted with screw in studs and pocketed for the taller springs to accommodate the higher lift. The 4bbl intake is an Edelbrock 2114 topped with a Carter 625 cfm AFB.
The body and taillights have been customized.. Currently the car is painted satin black. When I'm done building the car and testing it I'm painting it house of kolor organic green Kandy. For more pics of what I have done go to http://www.v6spider.com
This is my second build of this car. The first one was crudely put together. This version I'm doing as best I can to build it right. There are many other things I did to accommodate the v6 in the spider Customized front suspension and cross-member plus many other modifications were necessary in order to make this happen.. Anyway. Hope you guys like it..
Cheers!
Rob
Old 10-30-2014, 06:19 PM
LATECH's Avatar
Last journal entry: GTO Reproduction Hood
Now that's Cool.
Fact is stranger than Fiction
Old 10-30-2014, 07:00 PM
v6spider's Avatar
Thanks man!
Old 10-31-2014, 02:37 PM
v6spider's Avatar
Here's a shot of it on it's side in my garage. I re-enforced the subframe and converted the rear suspension from a 4 link to a 3-link to accomodate the dual exhaust out the back. The rear -end is a limited slip unit out of an 84 RX-7 GSL.
Cheers!
Rob
Old 10-31-2014, 05:08 PM
LATECH's Avatar
I would be real interested seeing that run down the track!
Nice job.
Old 10-31-2014, 09:59 PM
v6spider's Avatar
Not much hookup... But lots of fun all the same.. The transmission is a Borg warner t5 5 speed from a camaro. The bell housing is from a Chevy Monza spyder.. Cable pull..
Happy Halloween!
Rob
Old 10-31-2014, 10:08 PM
ericnova72's Avatar
More for Less Racer
Nice, I like it.
Looks like it was made for that V6, nicely done!
Love the tail lights also.
Old 11-01-2014, 12:23 AM
v6spider's Avatar
Originally Posted by ericnova72 View Post
Nice, I like it.
Thanks! I removed the sheet metal around the bellhousing area and fabbed in new sheet metal to make room for the trans. I also built my own steering using a 72 mustang II rack the shocks are retrofit mustang II coil-overs for a mustang II made by QA-1. They are 12 way adjustable damping. The brakes are from the same RX7 donor that the rear end came from. Steering arms are custom made and lower control arms are modified FIAT.
The taillights are 2 1/2" Truck Marker lights that were modified to work with 1157 two filament bulbs.
The tailights holes are 2 1/2" exhaust pipe..
Cheers!
Rob
Old 12-30-2014, 11:21 PM
v6spider's Avatar
Getting real close to firing the engine.
Old 01-28-2015, 12:06 AM
v6spider's Avatar
Got it running!
http://youtu.be/7mD-vUBLk8w
Old 01-28-2015, 11:27 PM
ericnova72's Avatar
More for Less Racer
Cool, sounds great I want to see it done and on the road.
If you can find a different air filter that fits, do it....those foam things are known for catching on fire easily if the engine ever backfires.....they are also a very poor flowing filter.
Old 01-29-2015, 03:55 PM
Rustydusty's Avatar
Junk junky
Last journal entry: Low budget/no budget sbc Spitfire build...
Nice work! That would look cool sitting next to my v8 powered Spitfire at a show. Where are you located?
Old 01-29-2015, 06:53 PM
v6spider's Avatar
Thanks guys. BTW I have to build a custom air cleaner so the foam one is out.. Not much hood clearance at all.. Like the spitfire... I'm in Washington state..
Old 02-03-2015, 07:38 PM
JGK95's Avatar
Last journal entry: Test Entry
V6,
I think your V6 Spider build is exceptional!
Looks like a lot of hard work went into building it.
The wheels...not a fan of them but they do give a stock/sporty appearance.
Jay K.
Old 02-03-2015, 07:50 PM
techinspector1's Avatar
Last wiki edit: DynoSim combinations
Wiki Edits: 326
Real nice there, spiderman.
chevy, v6 powered fiat, v6spider, vortec engine swap
Fiat Title ? Eastex Jr Hotrodding Basics 9 04-30-2012 10:51 PM
1937 fiat topolino value? americanLT1 Hotrodders' Lounge 7 06-04-2011 03:27 AM
Air powered or battery powered nailer? HotRodMan Garage - Tools 4 07-26-2010 08:09 AM
Fiat fever stingraydriver Introduce Yourself 1 04-28-2007 11:19 PM
