4 speed Saginaw shifting problems - Hot Rod Forum : Hotrodders Bulletin Board
Closed Thread
Old 08-30-2014, 12:01 PM
Last journal entry: 1979 Camaro Berlinetta
I have a 4 speed Saginaw in my 79 Camaro. Last month when driving it would be hard to put in 1st gear, a week ago the shift from 1-2 would be hard and sometimes grind, now I don't have reverse, 1st and second gear but I do have 3-4. I took the linkages off and couldn't even move the 1-2 lever. Took the side cover off and everything looked fine. Someone told me the 1-2 lever could have been stuck with the reverse lever. Can anyone help me?
Quick reply to this message
Old 09-02-2014, 07:41 PM
can anybody help me
Old 09-03-2014, 02:41 PM
Im sorry I missed this. I'll grab our builder and a schwaginaw and see if we can help you out. It'll be tomorrow though.
Old 09-05-2014, 08:04 AM
Thanks for waiting. Because a Saginaw has all three levers (the 1-2, the 3-4 and reverse) in the sidecover; the reverse lever can "block out" the 1-2 mechanism and you'd still have the 3-4. Fiddle with the reverse linkage and see if you can get it to move a little bit; then the 1-2 should clear. If not you'll have to pull the cover and take a look. Assuming no chunks of broken stuff (broken shift fork, broken synchro strut etc); this is your situation.
Old 09-05-2014, 07:45 PM
I took the side cover off and nothing looks bad, I think the 1-2 and reverse lever on the inside was stuck, on the reverse on the inside cover there's a spring and ball bearing.
Closed Thread
4speed, camaro, saginaw, transmission
hurst shifter, saginaw 4speed shifting problems latimermichael88 Transmission - Rearend 21 02-03-2014 10:01 PM
350sbc and saginaw 4 speed problems 1980gmcTON Engine 2 02-05-2011 07:12 PM
saginaw 4 speed linkage problems c_cham Transmission - Rearend 1 10-19-2010 06:33 PM
1960's 4 Speed Saginaw Speedometer problems usa3990 Transmission - Rearend 1 10-14-2010 07:08 AM
4 Speed Saginaw Problems borows72camaro Transmission - Rearend 4 06-09-2009 07:24 PM
