406 sbc stock crankshaft nitrous? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-22-2017, 05:44 PM
Question 406 sbc stock crankshaft nitrous?
Recently built a 406 sbc. I ended up getting a nitrous kit for a song after I built it and am debating on whether the motor will hold up or not. I would re-gap the rings but my main concern is the stock crankshaft. Will it hold up or not. Its approx HP is 450 and ft lbs of trq. I-Beam push rods. If I'm pulling the pistons to re-gap the rings I will change over to a forged piston but will the crank hold up to a 150 shot. Thats pushing 600 hp when its all said and done.
Old 01-22-2017, 08:13 PM
406 sbc
Originally Posted by 1935 chevy View Post
Recently built a 406 sbc. I ended up getting a nitrous kit for a song after I built it and am debating on whether the motor will hold up or not. I would re-gap the rings but my main concern is the stock crankshaft. Will it hold up or not. Its approx HP is 450 and ft lbs of trq. I-Beam connecting rods. If I'm pulling the pistons to re-gap the rings I will change over to a forged piston but will the crank hold up to a 150 shot. Thats pushing 600 hp when its all said and done.
The motor is built really well. I took my time and had a sectioned off a room in my shop that was a nice as any living room, warm and comfortable there was time to relax and do the job without cutting corners. I was aiming for around 500 hp and will achieve that by getting better flowing heads. I used the original crankshaft not thinking I'd use nitrous, but should have beefed it up as-well.
Old 01-22-2017, 10:20 PM
ericnova72's Avatar
More for Less Racer
The stock crank can handle that nitrous hit without a problems....just make sure your fuel volume and ignition timing are correct.
Best way to ensure this is to have a separate fuel pump and line for the nitrous along with a timing retad for the ignition.
Depending on the age of the nitrous kit, you may want to go online and look up current fuel and nitrous jet combinations....modern ratios are a lot different than what is provided in older kits. Testing and technology has shown that the older ratio's were far from correct.
406, crankshaft, nitrous, sbc
stock short block and nitrous! bottlefed55gasser Hotrodding Basics 1 12-26-2012 03:29 PM
stock 454 or 406 sbc done up 80camaroguy Engine 3 02-14-2012 08:47 PM
Limits of stock crankshaft and Rods Hammerchvy Engine 13 02-20-2009 10:07 PM
need help with cam for sbc stock 406 chevy350cutlass Engine 10 10-26-2008 12:09 AM
Crankshaft, stock or aftermarket MCsommerreid Engine 5 06-30-2006 07:10 AM
