454 4-bolt 445 casting - Page 3 - Hot Rod Forum : Hotrodders Bulletin Board
  #31 (permalink)
Old 02-10-2011, 03:50 PM
Originally Posted by ericnova72
IC-988 is a bit lighter(70 grams, 844 grams w/pin) and has 38cc dome. Would make balancing a bit easier and gaurantee it wouldn't need any mallory in the crank.
I can't even find that piston on KB/Icons website!
... found it now, that actually looks like the perfect piston for this setup then. (CR comes out to 10.4 at +.30)
  #32 (permalink)
Old 02-10-2011, 04:14 PM
Originally Posted by cobalt327
I cannot even say w/certainty that the 909g piston would need heavy metal- BUT- the lighter piston sure could help things in that regard.
The lighter slugs also would be more "rev-able", to boot. Less load on the crank and bearings.
But this will drop the CR down to 10.7:1, so be sure the cam is compatible w/that CR.
How are you getting that CR? I'm just using Icons website that uses .30, asking for cylinder head volume, which using a 781 head with bigger valves should open it up just a tid but more to something like 122ish? which is giving me 10.4:1 with those 988's. As I'm shooting for +/- .25 of 10.5:1, either way I think those'll be right on the money. Now I just have to find someone that stocks those, that aren't at retail price!
  #33 (permalink)
Old 02-10-2011, 09:16 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Except for the piston dome volume, this are the same values I've used throughout this thread. The zero deck w/0.041 compressed thickness head gasket can be any combination of gasket thickness and piston deck clearance that equals 0.041".
  #34 (permalink)
Old 02-10-2011, 09:19 PM
I see how you got that now, I was using a different compression ratio than you were, 122cc's (roughly what the head is going to be, putting me right on the money. Thanks though!
  #35 (permalink)
Old 02-10-2011, 09:23 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
...I was using a different compression ratio than you were, 122cc's...
Actually, that would be a different combustion chamber volume. The calculator I used is HERE.
Good luck.
  #36 (permalink)
Old 02-10-2011, 09:46 PM
you know what I meant!!
thanks
65-67 12 bolt Casting # Fastest65 Transmission - Rearend 0 04-22-2008 05:59 PM
questions about swapping R/E gears from a 12 bolt Gm into a Pontiac 10 bolt housing l Bad Rat Transmission - Rearend 6 06-11-2007 10:50 AM
Change 8 bolt front hubs/rotors to 6 bolt? (gm 3/4 ton) murrsue Suspension - Brakes - Steering 3 04-02-2007 01:05 PM
Can't Find Casting Date on 12-bolt PrimaDude Transmission - Rearend 0 03-11-2003 07:25 PM
2 bolt to 4 bolt swap and 2 bolt strength???? HemmiGremmie Engine 8 10-20-2002 03:06 PM
