454 starter rewiring - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 10-06-2014, 02:00 PM
T-bucket23's Avatar
Last wiki edit: Engine basic condition - how to check
Wiki Edits: 26
Originally Posted by chevyrestore View Post
I ditched that cheap mini starter and got a proform mini starter. needs a couple shims but bolted up MUCH better, got the wiring done with just that purple wire on the one small terminal. Cranking properly now but its spinning the motor and then grinding, then spinning the motor again. Looks like I need to play with some more shims and see if that fixes it. Thanks for all the ideas so far
Proform is not known for their quality and that is being very nice.
I am a big fan of the MSD starters myself
Chet
  #17 (permalink)
Old 10-06-2014, 02:01 PM
T-bucket23's Avatar
Wiki Edits: 26
Originally Posted by ntfday View Post
Put them together and it should fire
This is absolutely wrong. This will cause the starter to run anytime the key is on.
Chet
  #18 (permalink)
Old 10-09-2014, 09:10 PM
chevyrestore's Avatar
I broke one of the inner starter bolts so now I have to drill that out but in the meantime I did what some of the other threads here said and just grabbed a mini starter that used the in line bolts. bolted that up and sits perfectly with no shims EXCEPT the gear is basically resting on the flexplate. What I mean by that is it will kick the gear into flexplate with 1/8" gap like it should but then when the gear retracts it rests on the back of the flexplate (not engaged in any teeth) and will run against the flexplate while the engine is running.
It came with a couple washers and gaskets but I think those are only to clock the position and had no instructions. Any ideas how to make this one work since it fits so good without shims AND is already in my hand. Its like the gear needs to retract more but I verified its fully retracted
Heres the link to the one I got:
http://www.autozone.com/autozone/par...60_33796_4253_
  #19 (permalink)
Old 10-11-2014, 07:32 PM
found a similar starter pdf guide and figured out how to disassemble mine and get the internal shims on...working AWESOME now with the correct gap. Thanks a million for all your help everyone, cant thank you all enough. Now I'm off to go replace the battery I killed
454, bbc, mini, solenoid, starter
454 Starter choices Byronski Engine 6 06-09-2014 09:46 AM
454 starter problem barndweller Engine 8 05-25-2010 01:31 AM
454 starter problem engaging tonyhuffine01 Engine 3 04-29-2010 08:38 PM
flexplate and starter for 454 truckboy61 Engine 5 08-26-2009 09:58 AM
Help needed rewiring a rewiring on a 70' Charger DaSouthWon Electrical 5 06-24-2008 08:25 PM
