47 Merc hood, nothing to thread the hinge shoulder bolts into - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-02-2018, 02:41 PM
47 Merc
Bought a partially complete 47 Mercury rod. Is there an insert I'm missing in the hood where the hinge shoulder bolts thread in. Just open holes only hood, and virtually impossible to gain access to put a nut in there. Any help appreciated. 82 yr old fat fender lover.
Old 08-02-2018, 05:01 PM
Open up the hole large enough to slip a flanged nut in and weld it in place flush. Grind the surface smooth and wallah. Fixed!
John
Old 08-02-2018, 05:17 PM
One way I have done stuff like that too is to make a nut out of a piece of flat stock, 1/4" flat stock. Make it as big as you can still work with it. Drill a couple of holes next to the hole where the bolt will go to plug weld it in place. Stuff it under the brace fed through the hole with a piece of wire (mig wire works great) then plug weld it.
Old 08-03-2018, 08:09 AM
S10xGN's Avatar
Gotta love a turbo!
I was gonna say rivnuts, but this seems a better solution.
Russ
Old 08-03-2018, 08:38 AM
Russ
IF you can get in there, and you can cut a slot in the brace and weld it up after you get the nut in if needed.
bolting hood to hinges
55-7 chev hood hinge or hinge spring? bullheimer Body - Exterior 8 06-29-2017 03:35 PM
Nothing to do with nothing, but if you like Bob Cats--- boothboy Hotrodders' Lounge 2 04-09-2013 08:47 AM
47-54 chevy truck doors/hinge/cab dents. superdirt Body - Exterior 1 12-24-2010 12:11 PM
1952 Chevy Hood Hinge Bolts klif50 Body - Exterior 4 11-25-2010 10:03 AM
Seat / Shoulder Belt Installation on a 47 Plymouth kbuhagiar General Rodding Tech 2 09-12-2010 08:49 AM
