48 chevy p/u doesn't sit correctly - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 05-13-2014, 01:07 PM
NEW INTERIORS's Avatar
life is a temporary assignment
I thought it was... Can you give us a picture of under the hood... It seems like someone may have pulled out on the two side's at the bottom of the hood..
  #17 (permalink)
Old 05-13-2014, 01:48 PM
I actually have a little more to the story now. I talked to the guy who had the hood on his truck and he told me he had it on his truck without it being bolted on. When he hit about 55 it flew off the truck and landed on the highway which caused the damage.
The Following User Says Thank You to cornfieldcars For This Useful Post:
NEW INTERIORS (05-13-2014)
  #18 (permalink)
Old 05-13-2014, 03:43 PM
I have seen that myself a few times....
Now we know the rest of the story....
  #19 (permalink)
Old 05-13-2014, 06:57 PM
496CHEVY3100's Avatar
Last journal entry: 53 ad3100
Originally Posted by NEW INTERIORS View Post
is this a high and low here ??
Do you have the Hard rubber strip installed on the cowl yet ,,it will change how it fits ,, my suggestion is install it Before you do any body work ,,also it does Not meet in the middle only use the clips the come with the strip and cut rubber at the end of the inside clip. just my opinion
I had to install all the rubber bumpers to get mine to fit 4 in front 3 up each side and strip on rear ,but my hood had a lot of work. ,,this is the strip I was referring to.
  #20 (permalink)
Old 05-14-2014, 04:10 AM
The hood on my 48 chevy p/u doesn't sit flat on the passenger side right at the cowl. A body guy looked at it and said it was "stretched". I understand what he is saying and he said the way to fix it was to heat it and let it cool so the metal contracts and then hammer and dolly it flat. He is swamped with jobs and can't get to it any time soon and told me it is pretty tricky work. is this something a novice could do or will I screw it up completely?
I have a white 49 3100 with a similar issue. The back edge of the hood is flimsy and "oil canned". On my truck, the gap between the driver's side of the hood and the cowl is too wide. I need to elongate the holes in the hinge and that will reduce the gap making the flimsy back edge of the hood less visible. If you adjust the fenders lower so the hood sits tighter in the back that should help. I never thought shrinking metal was all that challenging. I have done it many times, but I would of course take the hood off to do it. It will make the underside of the hood a bit pitted looking.
  #21 (permalink)
Old 05-14-2014, 05:05 AM
deadbodyman's Avatar
Last wiki edit: Stripping paint
Wiki Edits: 11
I think I'd just get another hood,thats just the only spot you noticed because it sticks out like a sore thumb but once you get primer on it and start blocking your going to find more and more until its full of bondo from one end to the other...So save yourself some trouble, time and money and replace it. its just not worth fixing ,theres too many of those hoods around that are in great shape.. Of coarse you could always spray it in black primer and leave it.
  #22 (permalink)
Old 05-14-2014, 07:44 AM
I did that myself about 35 years ago. Can't imagine it would make sense to repair it, there are plenty out there.
'79 Trans Am doesn't sit right? muzzfactor Suspension - Brakes - Steering 2 02-27-2011 10:52 AM
Are my big block Chevy pistons installed correctly? 4speed57 Engine 4 08-01-2010 06:12 PM
C-4 Doesn't shift correctly Arrowhead Transmission - Rearend 2 05-16-2008 07:21 PM
Chevy engine doesn't fit Chevy Trans! 2000jack Engine 18 01-31-2008 10:51 AM
Chevy 350 not running correctly Evilgrinn Engine 4 02-22-2006 04:21 PM
