496 Stroker bulid sheet - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 02-18-2015, 06:36 AM
vinniekq2's Avatar
how about 290 cc AFR oval port heads(or check profiler) Vic Jr oval port,Boutique 950/1050 cfm carb and a cam like this isky;
396640 RR-640 3200-6800 .640 .028 304 264 intake and exhaust @ .050 108
  #17 (permalink)
Old 02-18-2015, 06:40 AM
If you want torque then get a head in the 265 to 305cc range. 320 is way to big for power to around 6000 rpm.
  #18 (permalink)
Old 02-18-2015, 06:41 AM
Originally Posted by StraubTech View Post
Just did a project for a guy on Chevelles.com. Promised him 600HP/600#/ft and he got 663/660HP.
10 to 1 Compression
AFR265 out of the box
Vic Jr with gasket match
950HP
B&B Oil Pan Kit
569/.569 235/235 .050 on a 108 Sep Hyd Roller
Morel 5374
Here is is your torque with a smaller heads and smaller cam on 496CID.
  #19 (permalink)
Old 02-18-2015, 08:24 PM
496 Stroker build sheet
Check out these Profiler heads. BBC 24 Degree Sniper Heads 174 Series. These heads are made in the USA. I would order them bare and have your machinist install the valves, and valve springs, retainers, and locks for your camshaft. If you are going to buy Chinese parts at least buy forged. Check with CNC Motorsports about a rotating assembly you will be better off than buying parts separate. Scat 1-42355BI BB Chevy 496 Competition Balanced Rotating Assembly - 10.5:1 Icon Dome Pistons - BB Chevy 496 Kits - Rotating Assemblies - New - Engine Components | CNC Motorsports | Car Parts | Truck Parts | Competition Engines. I bought a 496 kit from them with the Eagle forged crank, Eagle H-Beam rods, Icon pistons, Clevite H-Series main & rod bearings, and Mahle pre-fit rings. I asked to substitute Icon forged pistons IC789-040 instead of SRP's. I explained that my block was already bored to .040. CNC Motorsports customer service was easy to work with. Check out the MSD 8360 unlike the Street Fire they have advance stop bushings to setup the mechanical advance. You don't need to worry about low end torque go with the Victor Jr. intake and a Holley 950 cfm. Stay away from thumpr camshafts they are all noise. Check out this Lunati hyd. roller 20110549K. Lift .578/595, duration @ .050 232/242 2000-6000. I think you will be better off waiting to buy pushrods until the engine is assembled and measure for pushrod length.
496, 496 stroker, build plans
496 stroker for my 67 Maine1 Engine 3 01-11-2015 03:41 AM
496 stroker bblumberman Engine 8 12-17-2014 06:18 AM
496 horsepower? Guess? Should have dyno sheet Monday. C10 496 Hotrodding Basics 17 03-17-2014 10:14 AM
496 stroker setup schottout Engine 6 04-01-2012 09:52 PM
496 stroker orangecrush Engine 2 12-15-2002 06:56 PM
