4l60e no 4th or overdrive? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-26-2015, 09:49 AM
Hi there I recently purchased a 93 Chevy c3500 1ton dually with a 350. Truck runs great and has had a transmission rebuild roughly 30,000 miles ago. 1st, 2nd, and 3rd work as they should, but 4th will not engage. When you are in 3rd and let off the gas it idles low as it should as well. Any thoughts would be great! Thanks!
Old 03-26-2015, 01:45 PM
EDIT: the truck only looses 4th sometimes, it seems more often when it is hot. I have lost 4th and pulled over, turned off truck and let it sit for a minute, then it usually will engage for a little while longer.
Old 03-26-2015, 02:19 PM
jokerZ71's Avatar
Wrench Turner
Ck all wires,plugs,connections.Especially those associated with the TPS.(throttle positin sensor). Also ck oper ation of the TPS.Using a multimeter,probe the wires from the TPS with key on/engine off.Blue wire is 5 volt reference.You should have 5 volts.Black is ground.Gray is the signal wire.It should read approx. .5 volts with throttle fully closed.Slowly open throttle watching meter.Voltage should rise smoothly to 4.5 to 5 volts @ WOT.No spikes or flat spots.
Old 03-26-2015, 05:39 PM
sbchevfreak's Avatar
Licenced Automotive Technician
Would hazard a guess that the 3-4 clutch is weak... poor seals, which may explain why it is worse when it is hot....
Old 03-26-2015, 11:59 PM
pricesgarages's Avatar
a 3500 should be a 4l80
4l60e, 4th
no 2nd or 4th on 4l60e chevy1500z71 Transmission - Rearend 2 08-20-2013 08:21 AM
4l60e No 3rd Or 4th ytreffar57 Transmission - Rearend 7 09-09-2011 10:41 PM
4l60e no 2nd or 4th, cwdlylionb Transmission - Rearend 5 09-21-2010 05:34 AM
4L60E No 3rd or 4th Dannyv2221 Transmission - Rearend 1 12-27-2007 06:24 PM
4l60E 4TH problem Stanley H Transmission - Rearend 1 04-28-2005 07:48 PM
