4L60E no change in line pressure - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-01-2013, 09:29 PM
Hey guys, my buddy and I just rebuilt my 4L60E out of a 1999 tahoe. After reinstalling everything we finally put it in gear. Reverse first,not much movement... thinking there is air in the system we drove around for about 20 min. Still no power in reverse, just slipping. We hooked up a scantool and found 2 issues. First, the computer does not recognize Rev as a gear selection. P/N is correct and O/D, 3,2,1 all list correct on the scan tool. In reverse the scan tool shows a p/n gear selection.
Second issue is that line pressure is ~ 80 psi no matter what. Park at idle,or under acceleration and all gear selections. No change in line pressure.
With the scan tool we tried to test the PCS and no matter the amperage,line pressure remained constant.
Any help??
Old 12-03-2013, 07:42 PM
Any help??
Does it shift gears when it was moving?
Try very fine adjustments on the shift level at the side of the big external switch box on the drivers side of the trans. These tell the computer which gear is selected. The computer needs to recognize reverse as well as all the other selections.
Also, warm the beast up and shift it into gear then out a few times then check the fluid level with the engine running at normally warmed up operating temperature. Don't go out and drive, that will cause damage if all it has is 80 psi of line pressure in any and all gears.
Bogie
Old 12-03-2013, 09:33 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Did you replace the electronics in the trans during the rebuild process?
Mayb a faulty PCS
Old 12-09-2013, 07:59 PM
The EPC (electronic pressure control solenoid) is probably faulty and not responding to input from the TCM.
Also, if the transmission is not going firmly into reverse, or slips in reverse, the most likely culprit on a fresh rebuilt unit is a cut sealing ring on the pump stator. What type of sealing rings were used-scarf cut, or 1 piece teflon? Did you use a resizing tool on the sealing rings to insure that they would seat inside the drum without damage??? It's very easy to damage the sealing rings when putting the pump in. When you put the low/reverse piston in the bottom of the case, did you put new sealing rings on it as well?
Lastly, if the vehicle is starting in "N" and "P" as normal, the switch is not likely to be your problem. Further, if it is shifting through the forward gears normally when driving, the MLPS, or NSS, is not your problem.
4l60e, issue, line pressure, rebuild, reverse
4l60e Line pressure problem joshk Transmission - Rearend 1 12-26-2012 04:51 PM
How do you run line pressure test on a 4l60e ? old yukon Transmission - Rearend 5 05-28-2011 08:56 PM
2000 4L60E to an earlier 4L60E, What do I need to change out aquaterrarv Transmission - Rearend 2 04-08-2010 07:22 PM
4l60e - No reverse after rebuild - Low line pressure? reddeth Transmission - Rearend 5 06-03-2009 10:12 AM
4L60E Line Pressure problem (possibly) olimpalarider Transmission - Rearend 13 11-20-2006 03:55 PM
