Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 4L60E Screeching in Manual 3/2/1
Old 01-30-2019, 08:08 PM
Crosley's Avatar
Crosley Crosley is offline
Global Moderator
Wiki Edits: 1659
In the shifter position of 3 , 2 , 1 ... Not OD .. the over -run friction pack is applied. The clutch hub for the over-run frictions is weak. Often the center breaks out. This may be the cause of the noise you hear.
The Following User Says Thank You to Crosley For This Useful Post:
spfautsch (01-30-2019)
