4L80-E in 71 Camaro - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-22-2015, 01:41 PM
Last journal entry: 1965/66 Impala body lines.
4L80-E in 71 Camaro
I'm sure this has been addressed on here before, but I searched and came up empty. I've managed to get hold of a "95" 4L80-E out of a GMC 3500 TWD Van that I'd like to install in the "71" Camaro I'm building. Right now the 454 has a Edelbrock carburetor but I'm intending to replace that with an EFI conversion kit(probably a FAST kit). I'm also looking into a Dakota Dash insert. While pulling the tranny out, I took all the transmission wiring I could find, and the factory ECU. My queston is, can I use the GM ECU to run this transmission, or do I need to/ should I, go with an aftermarket ECU/TCU. Thanks in advance, hope I didn't leave out anything.
Old 11-22-2015, 05:10 PM
Wiki Edits: 31
Use a diesel gm controller. Its a standalone unit.
4l80, camaro, dakota, fast
98 4L80 e transmission nasty68 Transmission - Rearend 6 01-05-2015 06:04 PM
4l80-E spudman45 Transmission - Rearend 1 10-15-2004 03:02 PM
4l80 *Update* william27103 Transmission - Rearend 2 08-18-2004 01:22 PM
4l80 id? slider in wa Transmission - Rearend 0 11-12-2003 05:31 AM
4L80 Trans Gassman Transmission - Rearend 5 02-14-2003 04:53 AM
