5.0 base timing ???? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-21-2008, 03:03 PM
naughtyponygirl's Avatar
Last journal entry: just a few more favz
I have a 5.0 bored 30 over,hei distributer ,edelbrock rpm manifold,600holleydblp,,my problem is that I can not seem to find the happy medium , should I change the spring in the vacuum advance its too strong and then it seems to let go and give too much advance ??? my head is getting sore bouncing off the head rest ???!!! Well hope to hear sume feed back Thanx NPG
Old 09-24-2008, 08:56 PM
NPG, do you mean you have a 'flat spot' while accellerating, when the vehicle sort of bogs down? If so, it could be either a distributor or carb problem.
If you're sure the carb's OK, then the first step would be to change the distributor advance weight springs to a lighter set.
Crane sells kits for re-curving the distributors, which include sets of springs and an adjustable vacuum advance cannister.
Do I need vacuum advance? (Long Post) Chevy21 Engine 41 10-25-2007 01:23 PM
26 deg base timing, does this sound right? Mad_Max Engine 3 07-15-2007 02:55 PM
vacuum advance help batman09 Engine 14 09-09-2004 10:42 PM
5.0 liter ignition timing GTpony Engine 5 06-01-2004 12:35 AM
BBC Timing Top Rod Engine 0 06-09-2002 09:29 AM
